JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
You can port it if you'd like....although that little bit of flashing hanging over is not going to make or break your setup.
Most likely a T4 twin scroll 17cm^2 housing
And maybe something like this?
Shearer Fabrications - Products
Is that recessed into the feed hole? Something doesn't appear right about that oil feed fitting....it's like nothing I've seen on any Holset before.
.Was out doing some tunning running a little lean between 5500-6000 rpm little maf calibration is all it needs.
Nice! It does seem like all hell breaks loose after 6000 rpm.
Hey was recommended by Justin to post the picture of my oil feed on my H1C. It looks to be a recessed 5/8th inverted Flare fitting. Anyone else see something like this before? I have the drain setup now I'm just working on the feed portion of it, trying to figure out what adapters I need.
Seems like most holset h1c's have that recessed oil feed.
Here is a video I took of my h1c.
Don't laugh its a bad video.
VIDEO0002.mp4 video by dragonov_elite - Photobucket
I understand that, but I find it hard to believe I'm off 5mm because there are an odd number of blades. If it measured 52-53mm, sure. Even measuring the ID bore of the compressor housing gave me ~49mm.
Eww. You might have another oddball unit. An HX35g is probably one of those natural gas units, they generally won't have as big of a compressor as a diesel unit. If it really is only 49mm your in the realm of a 20g.
At least you can upgrade the compressor to a 60mm one for like $200.
Just to clarify for you. When measuring the diameter of a wheel with an odd number of blades you need to measure the radius and multiply it by 2, that will give you the diameter.
