dsm-onster
DSM Wiseman
- 8,592
- 131
- Jul 11, 2004
Bloxom,
Virginia
I doubt the bolton turbine housing with the standard hx35 turbine wheel will be enough flow for the 60lb/min 7blade hx35 (later hx35) compressor. It IS DEFINATELY enough for the 8blade 52 lb/min hx35 compressor. Since we've seen several 500whp bolton hx35 turbo setups.
The larger .70 a/r housing spool about 10% slower than the bolton housing when running an hx40 chra. I expect there to be about a 10% diference with the hx35. The hx35 reaches full boost at 3500ish rpms with 272s. This would put spool at 3900rpms. And possibly enough turbine flow to push the 60lb/min later hx35 compressor wheel.
I'd like to try it. But the stock hx35 turbine housing with the hx35 turbine wheel and the center divider knifedged has gone 132mph in the 1/4 mile with a full weight 1g awd. The full spool is right under 4000rpms. And requires a vband o2 housing, just like the .70 a/r BEP housing. . .
A little bit of lag is a good thing in this case.
It should at least be a faster spooling viable option to the full t3/t4 50-trim.
