Activity Feed
Live updates
  • We're on Boost replied to the thread Street Build ITFLYS - 1Gina2G.
    · 1,716 220,329
    Yay. Have you seen mine? You must be registered to see element. I have the same alternator on the car now that I put on it here in 2019 and haven't had to change or repair anything about the heat shield.
  • TasosEclipse replied to the thread 2G Oil leak.
    · 37 339
    Yes I put on the hose from the head to a boost gauge to check it when idling it was -0.2 -0.3 and when in boost it was 0.
  • Justin DuBois replied to the thread Street Build ITFLYS - 1Gina2G.
    · 1,716 220,329
    I need to build a heat shield!My guy has rebuilt 4 of these past couple years.He said he’s done all he can.
  • jmt2028 posted a reply to a question on the classified ad For sale 2g Mahle Power Pak Pistons.
    I'd do like $330 shipped, you cover paypal fee
  • DSMPT replied to the thread 2G Oil leak.
    · 37 339
    Did you make sure below one by one to determine the location where the oil coming from? You should do it first and then next you would figure why leaking and fix it. - Oil pressure isn't too high? - Inside intake pipe, intercooler and its pipings...
    · 1,716 220,329
    Been enjoying the fuel economy of E85. Never thought this 105 octane bullet would be cheaper to run than my wife’s Hybrid Rav4.So I think the voltage regulator is gonna die - again. You must be registered to see element.
  • jdxnc replied to the thread 2G FIC 2150 injectors with Radium fuel rail.
    · 12 195
    Those look taller than oem:You must be registered to see element.
  • jdxnc replied to the thread Goonie’s 90 GSX.
    · 228 39,711
    How's your base fuel pressure with that banjo fitting on the rail? Some of those can be pretty restrictive.
  • pottersgst replied to the thread Tuners.
    · 1 28
    South jersey here and I went remote tuning. Very simple took about 3 hours couple drives around with 3rd gear pulls and was simple enough. Couple people do it but I went with Ricky over at RIXRacing. Simple enough. But there is few guys that do...
  • jdxnc replied to the thread 2G Pressure plate bolt.
    · 6 104
    He was talking about using the socket head cap screws instead, which are taller than the oem.I'd just use oem and skip any potential headaches. There isn't much pressure on those bolts, it's the dowel pins that do the work.
  • jdxnc replied to the thread 2G Has anyone deleted the venturi jet pump?.
    · 1 50
    Never heard of anyone doing it and personally I think it's kind of overcomplicating the fuel setup. I ran the Walbro 535 with the oem venturi drilled out a little for more flow and it worked fine, car made 630whp on E85 on that setup.
  • 1cleangsx replied to the thread Weekend Warrior - 1997 Talon TSi AWD.
    · 45 5,066
    I can’t wait to chime in with experience once I verify my auto swap works LOL, I was in a similar situation, sick of never ending clutch drag issues with 580/480 numbers on my Jacks HD trans, I didn’t break the trans with 1400 miles, but I know...
  • Jesse009 posted a question on the classified ad For sale 2g 2G harnesses.
    Can you msg me I’m intrested I also need engine harness
    Give me a hard address and I'll get a shipping quote tonight
  • heresjimmy42 posted a question on the classified ad For sale 2g Mahle Power Pak Pistons.
    How much shipped to Ohio
  • LSM posted the classified ad For sale 7 Bolt 4g63 Bare Block For Sale in DSM Parts Classifieds.
    I am selling my 7 bolt 4G63 block. The block is bare besides the crank girdle and oil pan. It was plulled out of the '97 GSX that I was going to build. It was pushing 430hp at the wheels when I bought it and had no issues or oil leaks or...
  • Joh_ecp97 posted the thread Tuners in South Jersey Area DSM Forum.
    I’m in central Jersey own a 97 gsx thinking of upgrading my version 2 ecm to version 3. Dilemma don’t know any good tuners who are familiar with ecmlink and tuning dsm’s any suggestions for tuning shops? Addresses instagrams?List of...
  • Has anyone deleted the venturi jet pump in the factory 2G GSX fuel pump housing and replaced it with a low-pressure fuel pump? I've been spending entirely too much time calculating flow rates based on hose diameter on: You must be registered to...
  • heresjimmy42 posted a question on the classified ad For sale Garage clean out.
    Do you still have the hks cams
  • pauleyman replied to the thread 2G Pressure plate bolt.
    · 6 104
    I dont understand what you're asking. These are the stock bolts correct? I see no issues.
