Activity Feed
Live updates
  • Colin rosti replied to the thread 2G Pressure plate bolt.
    · 6 104
    Thanks, I’ll defiantly reuse them. I noticed the unthreaded part before but didnt quite realize whats its for.
  • MindBlowin03 replied to the thread Weekend Warrior - 1997 Talon TSi AWD.
    · 45 5,067
    That's also an option since I'm not in a rush and the end goal is to be ready for 2027.
  • dwb replied to the thread 2G Pressure plate bolt.
    · 6 104
    Head size isn't a big deal, but keep in mind mismatched bolts can cause balance issues. I'm not pushing high HP but I've reused mine over 280k miles, 30+ years, 6 or more clutches and two different flywheels. No problems so far. YMMV
  • miguel angel posted the thread Mi carro al encender no responde al 100 in Newbie Forum.
    Y he tenido varios problemas con unas fallas que trae pero no las puedo encontrar no sé si ustedes pueden ayudarmeYou must be registered to see element."And I've had several issues with some faults it has, but I can't seem to find them; I...
  • Stizzydrew posted the classified ad For sale 420A Valve cover in DSM Parts Classifieds.
    Powder coated candy red , used $60 located 91321 Santa Clarita California Can ship
  • DreamChaser7 replied to the thread Weekend Warrior - 1997 Talon TSi AWD.
    · 45 5,067
    Wait for the Neat gearset? :idontknow: Hopefully not much longer… Anyone seen any new updates on the Fecesbook?
    · 6 104
    The bolt head, im thinking i might reuse the old ones as long as they can hold an aftermarket pressure plate.
  • DP_52 replied to the thread ECMlink First post! ECU question.
    · 8 193
    Just an update.Cleaned and reinstalled the spark plugs, car cranks and acts like it wants to start but doesn't.I did order the cable for the DSM link so I can check everything on the car as far as the ECU.I appreciate all the help
    · 6 104
    Threaded end or the bolt head?
  • Joh_ecp97 replied to the thread 2G Crank no start.
    · 5 130
    Thankyou very much 🙏
  • Anfurnyy replied to the thread 2G Oil leak.
    · 38 342
    Okay, understood now.1) check your oil level and make sure it's not too high. This could cause the crank to spin into the oil and make excessive oil vapors while running.2) check your valves through the intake and exhaust ports. If your valve...
  • TasosEclipse replied to the thread 2G Oil leak.
    · 38 342
    yes it was the turbo i changed to a new turbo and stopped but the oil consumption did not
    · 38 342
    I thought there was no oil in the charge pipes? If there's oil in the charge pipes it's either PCV going back into the inlet of the turbo or your turbo is leaking oil into the compressor housing.
    · 38 342
    That’s how much I put on I don’t know anything else I have to check.
  • dwb replied to the thread 2G Oil leak.
    · 38 342
    5 quarts
    · 38 342
    All at once I saw oil on the charge pipes and so I get the turbo checked and told me it needed new so I changed the turbo but the problem still persist. Another question how much oil you put on the car.
    · 38 342
    You didn't happen to use any RTV when installing the drain?Did you notice if this issue gradually happened or all at once?
    · 38 342
    The turbo is new and I made sure everything is ok with the drain . It drives me crazy were the leak is
    · 38 342
    Another idea is to add floresent dye to the oil and go for a nice long spirited drive. Then go back through cc breathers, intake/turbo, and valve stems (this one might be tough) with a black light.I'd also double check the turbo drain is...
  • GST2012GSX posted a reply to a question on the classified ad For sale 4G63 JMF T4 divided Top mount manifold..
    If shipping is a problem Im sure I can work something out for you.
