brian9397gsx
- 1,551
- 91
- Apr 28, 2008
sioux city,
Iowa
I think the 14B runs a 6cm exhaust housing. Vs. the 16Gs 7cm exhaust housing
your right thats why i said 7cm in the garage and the 14b on my 1g
You only need to scribe the wheel and shaft if you know for sure that the turbo was not balanced as a rotating assembly.Interesting
Would there be any balancing issues since this new compressor wheel was not balance with the shaft/turbine wheel assembly??
Because I thought that was the reason to scribe the compressor wheel to the shaft position when taking any turbo apart.
Thanks for all the info, Justin and, fellow members.
I started with two choices for turbos and now I am at four choices:
68HTA
Blouch 20g
FP 20g with my own 7cm housing (have to modify actuator)
FP E3 16g and then buy this ebay 20g Monster kit
I can honestly say the last option is in the lead...
I just hope there aren't any drawbacks I am not seeing.
I've researched it a bit. The drawback is the small compressor housing doesn't flow as well as the larger 20g compressor cover. So that will lower the efficiency. From what I'm told it limits the upper range more. So it will spool great down low and have a really strong mid range then fall off. Where a 16g will have a slightly better top range with less low/mid range.
I'm running 35+ spikes to hold 25psi to 6500rpm on my e316g. So I was looking into the same options as you. I was thinking a 10cm rear housing on the 16g with the 20g compressor. By the time that was built I could probably just buy HTA series 16g and be done with it. I'm torn....
No, an eBay knockoff will not work due to the shaft spec.would an ebay evo 3 16g knock off work cause those are pretty prevalent id assume
Your HX35 is worth roughly $300-350max on average.. Where can you find a 20g for that price?
I would sell it as a package with BEP housing, 4" intake and -10an drain line for around $500. I'm sure there are a few other things I can get rid of. Then I could pick up the FP 20g and slap that in.
DSMs are still a faster/better plate form than most of the so called tuner "cars"
240sx's cant touch these cars aside from weight is there advantage
I still dont understand why DSMs havent jumped in prices
Ive been looking to buy cars and its hard not to buy another
There is nothing special about a car that's a dime a dozen. Plus, evo's are a much better platform and share the same goods
For a much better platform, they have slower times.
i sucked it up and purchased that 20g from fp. its a thing of beauty cannot wait till this spring to throw it on
