v8s_are_slow
- 2,824
- 280
- Sep 30, 2002
Panama City,
Florida
There is an 8cm² TD05h version of the T3 housing as well that might be a good compromise between the two. The only issue is finding one.
Maybe someone who is better at finding things than I am knows where to get one. I've been looking for one for a while, but no luck. My problem is that I'm more or less stuck with the T3/syty housing setup, but I'd like to run a TD05h turbine (currently a TD06/8cm² housing). It's not what I'd call "laggy" but better response would be a good thing, and I'm on E85 so there's no real issue with needing more boost to get the same power.
Part number for the 8cm housing is 78-14200. The only application I know of for sure that it was used on was the HKS 16g kit for the 3SGTE. The part number suggests it's from the same casting lot as the 10cm² housings, since all the TD06 housings begin with 79-1xxxx. I've even considered machining an insert out of inconel to allow the 05 wheel to fit in an 06 housing, since those are readily available.
Anyone know how the 20g/TD05h-10cm² spools relative to the 20g/TD06-8cm²? (does anyone even use the latter on DSMs?) I see 20psi by 3500rpm on the TD06.
It's also possible to open up the wastegate section of the housing for better flow too if using the internal gate:You must be logged in to view this image or video.You must be logged in to view this image or video.
The syty guys report pretty noticeable gains, though it requires a new DP flange and some fab work.
I dunno but how is that thing suppose to seal properly with the wastegate on one end, and 3 bolts on the other??? If you used a copper gasket, it'd get burned out in no time. Burned, burnt, whatever.
I for got about this thread re read my post and saw were the confusion between myself and paul started, in my post 37 that should of been internal gate not external.
