snooopy365
- 198
- 4
- Jan 25, 2003
XX,
Europe
11.8:1 isn't "lean" for E85. You can get well into the mid-high 12's for AFR and still be completely safe. This car was tuning in the mid-high 12's for AFR and 22+ degree's timing across the board.
http://www.dsmtuners.com/forums/dyno-talk/350097-wingz-performance-hta35r-701-59hp-2.html
just wanted to add that ever AFR we are talking about is an immaginary AFR, because the scale is for gasoline and we are using E85 so the acctualy AFR when your gauge shows: 12.5:1 is = 8.3:1 !!
because stoich with gasoline is 14.7:1 and the AFR gauge is just messuring lambda and think it is gasoline. (btw. 9.76:1 is the real stoich E85 so that is what your accutaly running when your guage shows 14.7:1)
I just try to make everything with lambda, so my fueltables show lambda, that is way less confusing when you have different maps for different fuel (just my opinion)
maximum lean power with E85 is at lambda 0.8673
maximum rich power with E85 is at lambda 0.71
in my opinion its no problem to hit the 0.86 and not running any richer or leaner.
Why? because your injecting 40% more fuel than you would with normal gas, and E85 burns colder.
there is no need for "safty"... (btw. 0.86 would be 12.75 on your gasonline AFR guage)
) I took some fuel out using my sliders and added 2* of timing across the board.
Sams tuning it on the dyno on Friday night, we'll see what it actually puts down to the wheels after Sam's Chino Toon.
