- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 16g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Drag Race
- Mods-Bolt-on
- • Forced Performance 68HTA v1
• Forced Performance 4" intake
• Tial 50mm BOV
• Evo III Throttle Body (rebuilt by snowborder714)
• Evo III IM ported by Curt Brown (RIP)
• ETS Super Short Route FMIC Core - 26x11.5x4.0
• VRSF 2.5" IC short route piping
• Fuel Injector Clinic 2150cc injectors and resistor delete plug
• Aeromotive Stealth 340 fuel pump (hardwired)
• Proclassic -6AN fuel hose (feed and return)
• HEF Motorsports fuel line holders
• Flex fuel sensor GM# 13577429 mounted on firewall with a Engineer Freely billet mount
• Fuelab 818 fuel filter (40 micron metal element)
• Radium Engineering fuel rail + FPD-R
• Fuelab 515 adjustable fuel pressure regulator (43.5psi base fuel press)
• Forced Performance race exhaust manifold
• TPP black exhaust manifold blanket
• Tial 38mm wastegate (1.3 bar spring)
• Punishment Racing o2 housing (dumped to atmosphere)
• Apexi GT 3" cat delete dp (DEI titanium wrapped)
• HKS hi-power catback exhaust
• Archer Fab modified turbo back with vband clamps and Fathead Fab modified to fit under subframe
• ECMLink IR boost control solenoid
• Nology hotwires spark plug wires
• NGK BR8EIX spark plugs gapped to 0.025"
• Zaklee clear cam gear cover
• Prothane side motor mounts
• Boosted Fabrication chromoly crossmember/front roll stop
• Adam Porto solid rear roll stop
• AFCO 80107N race radiator
• 16AN Earl's radiator hoses/fittings
• 143* Mishimoto thermostat
• Single 12" pull fan
• Odyssey PC680 small battery (15.4lbs) relocated to subframe with JMFab tie down
• Frontline Fab billet valve cover anodized black with Radium ORB fittings
• Calan VS2 catch can 10AN inlet and 8AN outlet
• Vamos Fab 4" front drive shaft loop
• CNC 412 staging brake (plumbed to lock-up front right & back left) with fabricated hardlines
• Gofer Aero 100% carbon fiber bumper shutters
• Jay Racing alternator relocation (steel)
• Frontline Fabrication spare tire delete
• EDM tail lights
• Power steering deleted
- Mods-Engine
- • Arizona pump E-54
• Forced Performance FP2 cams
• Brian Crower adjustable cam gears (I/E both set to 0)
• Kiggly HP beehive valve springs (97lbs at 1.440")
• OE Evo rockers
• engnbldr SS valves
• engnbldr bronze valve guides
• Topline revised lifters
• standard ARP head studs (tq to 90ft lbs)
• OEM Mitsu composite headgasket (copper sprayed)
• Fluidampr harmonic damper crank pulley
• stock 7-bolt bottom end with 100k+ and balance shafts
• 2gSpyder4g64 CNC billet CAS cap
- Mods-EMS & Logging
- • ECMlink (V3) Speed Density with flex fuel and boost control
• John Fruend PiLink w/ 7" touch screen display mounted in center console
• Innovate MTX-L wideband (rear o2 location)
• AEM Digital (50psi) boost gauge
• AEM X-Series (100psi) oil pressure gauge
• AEM X-Series (100psi) fuel pressure gauge
• AEM 5 bar MAP sensor (iMAP)
• AutoMeter 2246 0-100psi MAP (eMAP)
• AEM 2 bar MAP (crankcase psi mounted on valve cover)
• GM IAT on UICP
- Mods-Drivetrain
- • AWD GS-T conversion
• Auto converted to 5 speed manual
• ShepTrans stage 4 w/ 4 spider CD, LSD, Evo 1st, 3rd, 4th gear and REM ISF
• ACT Twin Disk
• Frontline Fabrication girdled steel rear diff cover
• Jeff Bush transfer case brace
• KDN x Boostin Performance Money Shifter with 2nd gear lock out
• Shep trans solid shifter cable bushings
• ExtremePSI SS full clutch line
- Mods-Handling
- • SPC front UCAs with SPC P/N #660306 ball joints
• Paul Volk (99gst_racer) chromoly tubular rear subframe, LCA's, and toe arms
• Paul Volk (99gst_racer) chromoly tubular front control arms
• EMW depowered (Miata mod) 2g steering rack
• Evo rear Brembo brake calipers
• RotorPros CD/S rear rotors
• Hawk HPS rear brake pads
• Wilwood 4-piston front calipers (120-6816)
• Wilwood front rotors (160-5841)
• STM light weight front drag brake caliper brackets
• Wilwood BP10 front brake pads (150-8850K)
• 2003 Eclipse 8+9 brake booster and 17/16" master cylinder
• SS brake lines
• Dennis Grant Far North Racing spec Koni coil overs
• Hypercoil springs (750fr / 350r)
• Momo 350mm Tuner Steering Wheel
• Sparco Evo 2 driver seat
• RMDSM sway bar (rear) and OE front sway bar
• DC sport rear strut tower brace
• ARP extended wheel studs
• Enkei RPF1s 17x9 +35 wrapped with 245/45/17 Bridgestone Potenza RE760's
• Enkei RPF1s 17x8.5 +35 wrapped with 245/45/17 Hoosier DR's for the track @ 22psi
- Parts Wishlist
- • 8-point roll cage
- Background
- 11.49's or bust!
- 1/4 Mile E/T
- 11.634
- 1/4 Mile MPH
- 126.050
- 1/8 Mile E/T
- 7.623
- 1/8 Mile MPH
- 99.220
- 60' Time
- 1.941
- Timeslip Video Link
- Watch Video
- Timeslip Details
- Track Name : Wild Horse Pass Motorsports Park
Nitrous : No
Fuel Used : E85
Vehicle Weight : 2930
Tires : Drag Radials
Sponsored Car : no
- Dyno HP
- 437.9 whp
- Dyno TQ
- 387.9 lb/ft
- Dyno Type
- Dynapack
- Dyno Shop Name
- Road Race Engineering
- Dyno Session Details
- Nitrous : No Nitrous
Fuel Used : E85
Turbo : FP HTA68
Boost : 29
Videos
my first time at the 1/4 mile track
living in san diego we have no 1/4 mile tracks and the closest one is 2 hours north up by LA and they rarely have open racing. what we do have in SD is an 1/8 mile track setup in the chargers football stadium (qualcomm) parking lot so technically this was my first time racing my car at an actual "track".
i tracked the car untuned on an SAFC after i got home though i was so pissed at my time/trap speed i ordered link v3 and its on its way to my doorstep as i type this. anyway, heres the video of my first time racing the car at the track... enjoy my botched awd launch and poor 1/4 time for the mods i have.
id like to thank the camera girls alex (vergetsi), rigo (camposr), & rene (SD99GST) for filming and talking crap even though all of their cars currently can't move on there own.
id also like to thank the announcer for being a jackass...
HTA68, FP2 cams, & E85 runs 12.0 @ 116
Finally made it to the 1/4 mile track on my new setup after coming off the dyno with 437 awhp/387 tq. For more info on the modifications go to my HTA68, FP2 cams, E85 thread.
I'd like to thank Kris (banishedmunk) for all his help on my car, it would be NO WHERE near where it is today if it weren't for that guy.
11 second DSM
Finally put the car into the 11's!!!! None of this would have been possible with my good DSM friends that put the car together with me whenever it breaks and have taught me everything I know. Thanks!
Mitsubishi GS-T converted to AWD. Below is the COMPLETE modifications list from bumper to bumper...
Bolt-on Modifications:
FP HTA68 â–« FP intake â–« tial q bov â–« 1g NA tb â–« BJ's SMIM â–« VRS fmic 28.5"x10"x3.5" â–« 2.5" short route IC piping â–« FIC 950's â–« walbro 255 fp (STM rewire) â–« proclassic -6AN from tank to rail â–« fuelab fuel filter (metal) â–« 1g fuel rail â–« fuelab afpr (55psi) â–« 2g exhaust manifold (ported) â–« PR externally gated o2 housing dumped â–« tial 38mm wastegate with a .9 bar spring â–« apexi gt 3" cat delete dp â–« HKS hi power catback exhaust â–« hallman mbc â–« nology hotwires â–« prothane motor mounts â–« mishimoto radiator â–« (1) SPAL 12" push fan â–« optima red top â–« RRE oil catch can â–« '99 black leather interior â–« cf headliner â–« cf turbo spoiler
Engine Management:
ecmlink (V3) Speed Density â–« AEM UEGO wideband (rear o2 location) â–« AEM 3.5 bar MAP sensor â–« GM IAT â–« autometer boost gauge â–« HKS type 1 tt
Engine Internals:
E-85 â–« fp2 cams â–« Evo IX valve springs & retainers â–« engnbldr SS valves â–« engnbldr bronze valve guides â–« topline revised lifters â–« ARP head studs (tq to 90ft lbs) â–« mitsu composite headgasket (copper sprayed) â–« stock 7-bolt bottom end with 100k
Drivetrain Modifications:
AWD GS-T â–« automatic tranny converted to 5 speed manual â–« ACT 2600 clutch â–« ACT chromoly flywheel â–« evo X gsr shift knob â–« B&M short shifter â–« symborski shift kit â–« SS full clutch line â–« slave cylinder extension rod
Suspension Modifications:
GSX brake conversion â–« ss brake lines â–« eibach sportline springs (changed to prokit march '10) â–« tokico 5 way adjustable gas shocks â–« front & rear RMDSM sway bars â–« RRE front strut tower brace â–« DC sport rear strut tower brace â–« matte black evo IX wheels wrapped with 245/40/17 bridgestone potenza RE760's
DSMs at California Speedway
Feb. 28th 2010 at California Speedway. Eclipse running a s16g, ECMLink, FP2 Cams, 21psi. Talon Evo III 16g, built motor, 91+Meth.
DSM runs 7.9's
Finally got the car back to the local 1/8th, it had been over a year since I made a pass and of course my first launch it breaks. Good thing it was all good after we got her back to the pits, it felt good the next couple runs.
11 second DSM
Engine Management:
Engine Internals:
DSM runs 7.9's
