What Turbo is this? [Merged] Turbo ID Identification
Most aftermarket IC pipes are either 2.25" or 2.5". Depending on which one you get, you may or may not need a reducer coupler to match up to your desired FMIC.
I don't think anyone sells a 2.5" j-pipe....the biggest ones I've seen were 2.25", which are still a huge improvement over the tiny stocker.
Although I am curious....why a FMIC with a 13G? You'll have to keep an eye on core efficiency when making your intercooler selection- a knockoff intercooler kit with too much piping or a core that is far too big will have to much pressure drop, making your car feel slower until you upgrade the turbo.
Some FMIC kits have the lower pipe reduced towards the turbo outlet specifically to fit the smaller J pipe. Or is that just for the 2g kits.
Yup it in fact is a 13g. You can easily swap it out for a 14b/16g however reusing your factory water and oil lines. Cheap upgrade in itself and well worth it.
Monster....you're catching up to me!
1- T25, 1- 14B, 5- Small 16G's, 2- Big 16G's, 4- Evo III 16G's (one's a knockoff), 7- 20G's (including two Frank 20G's), 2- SBR G50's, 2- SCM 5027E's (junk), 1- SCM5031E (also junk), 1- SCM 6152E (bad turbine), 1- V-Trim (bad turbine), 1- HX35, 5- HX40's, and a shelf full of MHI center housings and turbine housings.
It's almost to the point where I need a seperate storage shed just for my turbos. They're starting to inhabit my main shop work area!
13g oil and water lines do not match. The waterline banjobolt on a 13g water line fits a 14b/16g oil feed line. And the 13g oil feed line banjo bolt is smaller.
This guy is good....I just did the evo 3 install from a small16g, from a 13g, on an automatic. So this guy knows his sh**. WOW..:thumb:
thanks guys, i believe he wants me to try and sell this thing, what would be a fair price for one ? looks to be in nice shape, fins on the turbo are nice, very little play in the shaft, no cracks in the housings, i have a little experience with turbos, just not this type. i believe thats why he asked me to help him.
if it's a t25 i really doubt that you will get 80 for it. nobody really wants the t25s. your best bet would be to try selling it to some honda kids, i heard something awhile ago about them using mitsu turbos... fair price would be anything from 50$ upwards, see what you can get and then let me know, cause i have one lying around too LOL
I'm not trying to hijack this thread but.... where on ebay is there a t25 with any bids on it? the t25 is TINY and it's basically useless unless you're doing a twin turbo setup or driving a honda.
