Please Support JNZ Tuning
andy4g63's Talon TSi AWD
Eagle Talon TSi AWD
HOLSET HX-40,with a T3 flange in a 0.70 AR turbine housing from BEP,with a 3" v-band .
ERL cast stainless T3 exhaust manifold,custom 3" O2 eliminator DP with a VRS exhaust.TIAL 44mm WG,TIAL BOV.63mm,bored out NT TB form throttle bodys.com.JMF intake manifold,catch can and ovrflow bottle.Custom extremely short route,aluminum IC piping from ENZO racing.Optima red top battery/relocated/.RC 1000cc injectors,BPR7ES spark plugs,ACCEL wires.Wallbro 255-in tank,BOSCH 044 inline.1G fuel rail polished with 8AN fittings,Aeromotive FPR,Aeromotive fuel filter.EARL's 8AN fittings,back and forth Earl's -8 stainless fuel lines.EXTREME PSI intercooler 8x24x3.5.Perma-cool 12"-3000CFM rad.fan,10 slim fan in front of radiator.FLUIDYNE radiator,Mitsu OEM thermostat/180*,Greddy cap.
Mods-Engine
BLOCK:
JE 9:1 0.020 pistons,Eagle rods,ARP hardware everywhere,ACL bearings.Mitsu OEM polished and balanced crank,Mitsu MLS head gasket,ARP studs.BC 280 cams with a BC titanium springs and retainers,SI stainless 1mm oversized valves,3G lifters,Fidanza's adj. cam gears.
Mods-EMS & Logging
AEM EMS,AEM UEGO gauge,AEM serial gauge.EGT,water temp,boost,oil pressure,turbo timer by GREDDY.
Mods-Drivetrain
DOG BOX Race tranny,incl.new gears 1-4,new synchros everywhere,doble synchro on 2gear,all beaqrings,seals.4 spyder center diff,replaced input shaft,brand new OEM intermediate shaft,replaced also 5 gear.OEM axles,Symborski shifter base bushings,MachV shifter linkage bushings.Prothane motor mounts.ACT 2600 PP with a 6puck sprung hub disc,ACT chromemoly Streetlite flywheel.Stainless clutch line,new slave and master cylinder.Manual steering rack from a 1990 car.
KYB GR-2;EIBACH Pro-kit,adj.camber bolts
BRAKES:
2G front calipers with a BREMBO 2g slotted rotors,EBC Yellowstuff pads,Braided stanless steel lines.Rear Akebono ceramic pads,oem rotors,stainless lines.
Parts Wishlist
Beefier rods/CROWER,Howards/,HTA 88mm turbo from FP,paint job.
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Sponsored Car : no
452.0 lb/ft
Dyno Type
DynoJet
Dyno Shop Name
Ivey Tune
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : Holset HX-40
andy4g63
More in 1G DSM
Share this Vehicle
