What Turbo is this? [Merged] Turbo ID Identification
Well, i'm happy with what it is and the shape it's in. No need for an upgrade then. Thanks guys. the little lady will be pleased.
I beg to differ. There are 7-blade versions of the 3071, 3076, and then obviously the T04S 60-1. He gave the factory number (700177-11), it's a GT11...though I do stand corrected, it's still based on the larger 3076R turbine as noted by this Garrett listing with all of the part numbers and their corresponding compressor specs: Garrett Master Turbo list
I meant to say "like 60-1" there are no 7blade 3071s.
the wheel is the best wheel to be mated to the 30 turbine. its like a mini 60-1. and KTS makes a 7 blade billet wheel for it too. bottom line I drove one and its a nice snail for the money.
My small 16G with a EVO turbine housing has:
Compressor Inducer diameter of 1.620 inches and an exducer diameter of 2.162. Looked at all the tables and cannot find a 16G with this set of dimensions.
Any suggestions.
Could be easily upgraded on the compressor side with machining to the cover, but you wouldn't be upgrading the turbine unless you swap the entire CHRA....so it will always be a "GT28xxR" if that's indeed what turbine it uses.
Can you tell me what type of turbo is this? So far I know is a holset from a 94 dodge cummins
Yep, looks like an H1C or H1E. My guess would be H1E since it appears to have 6 bolts on the turbine housing. Either way, you should take measurements of the wheels to see exactly what your working with. They weren't all created equally.
So this will be as the hx35, but in a older version?
I dont have the turbo to take measurements, a guy is selling me this. And i think the price is right, (125 shipped to my house) he is not ghat far from where i live so might just go and get it my self, just to make sure everything is good.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
