What Turbo is this? [Merged] Turbo ID Identification
i got this turbo from a friend of mine. he rebuild the motor on a dudes gsx and the owner wanted the car "all stock", so he replaced the turbo and got this one for free. the owner of the car said the turbo was an "upgrade" but didn't specify anything else. im not sure if its a t25 or t28. i've been searching all day and just cant get a definite answer. the only way i can seem to find, is to take the compressor housing off and measure the wheel with a mic. i though maybe you guys could help.
pics
An easy way to tell is the number of blades on the turbine.
11 blades: T25
10 blades: T28
9 blades: Big T28
thanks guys. your life savers. its a t25. any idea what he mean by upgrade? maybe he was just wrong.
Shoguy- It wouldn't be the first time someone selling a car lied. It's the stock turbo and not good for much HP at all. Not very reliable either.
OP- It wouldn't be the first time someone selling a car lied. It's the stock turbo and not good for much HP at all. Not very reliable either.
its for a low boost twin turbo budget build. 10 psi max. each bank is 1.6l and if i can get 175 hp each bank i'll be happy.
whats so unreliable about them?
Then it might be okay. I'm no turbo expert so I can't pinpoint the reason for failure. But every T25 I've had in my hands had massive shaft play, blown oil seals, and a cracked wastegate port. They are well known for failing and don't flow much at all, regardless of PSI.
Actually, one of the first things guys do to a 2g DSM is get rid of the T25 for at least a 14b or 16g. Most of time not by choice.
the one i have has no shaft play and seals are good. im picking another one up for $50 with supposed no shaft play. for that price, i'll give them a try and keep a close eye on them. the sho engine does like alot of air flow. so if they choke up top i'll change them out. thanks for the tip though. when i go pick that other t25 up i'll check for those problems.
you guys have been great. thanks for the help. too bad i don't have a dsm. you seem like a nice bunch to chat with. :)
So I just bought a B16g from a seller on here and just wanted to confirm. It looks like the "42" has worn away. Is there any other way to tell if in fact it is? Preferably without taking it apart. I attached some pictures. Also I just wanted to add that the seller said that he still had the 6cm housing so it spools a little faster.
@JusMX141 Thanks for the confirmation. I didn't think the seller was lying, but at the same time I just started to get into tuning, and wanted to make sure.
I picked it up for $250, and seemed like a really good deal. I have usually seen used ones go for $400-500. P.O. said it was rebuilt 3-4k ago. No shaft play, and no gouges near the turbines. A little dirty but nothing a wire wheel/dremel can't take care of.
I was planning on porting the housing out to 7cm though, that would work right? I wish I could just grab the install kit, and put it right in. I mean I COULD, but I want to do ALL general maintenance first. My head gasket went so I am taking care of that along w/ 60k maintenance (all new OEM timing components + water pump) After I finish w/ maintenance I might, but I don't have supporting mods yet. I know I could get away with running 10-12 psi, but I'd rather do it the right way the first time.
need some help identifying my turbo has t3 housing :confused:
Often I wonder how every used turbo was "just rebuilt less than 5k ago". :hmm:
Hahn Super 16G.
Can't believe someone put that turbo on an ERL manifold. You either need to upgrade the turbo or downgrade the manifold / turbine housing- you're losing about 500rpms of spool that you're not making up for in the turbine flow department over the same turbo with a 7cm DSM bolt-on turbine housing and manifold setup.
Oh it'll work just fine, it's just not suited for that turbo too well. The 10cm turbine housing favors high boost levels or lots of turbine flow, neither of which will be generated by that particular turbo. There's a 20G here that would be a direct replacement but have much better boost efficiency in the higher RPM range, but honestly that manifold flows so well it would favor something much larger than even a 20G....and being FWD, I'm sure you'll appreciate a little lag.
You'll never have to upgrade that manifold as long as you own the car- they're an excellent piece.
Thanks for the info appreciate it
I'm trying to figure out what turbo this is...was told it was a Bullseye 50 trim but I'm not too sure about that.
Has a mitsubishi flanged hotside and o2 housing.
Oh and if possible could someone tell me what hotside housing I could swap for a t3 inlet and keep the mitsu o2 housing?
Pics...
Bullseye T04B V-Trim.
Pics...
None.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
