chrisman287
5+ Year Contributor
- 1,158
- 1,113
- Jul 19, 2021
New York
I really like non insulated butt connectors followed by heat shrink tubing. Super solid connection and foolproof.
This.If done properly, either method can produce quality results.
I also work in the aviation field. Contrary to what's been said previously, a solid crimp is all that's used for our new harnesses.
In the past I soldered all my wires (repairs) and I swore that's the only way to do it. I had OK results, but it was not always easy. Technique and work area has a lot to do with it. Sometimes I'd have the solder wick up the wire (poor technique/too much heat) and that's when the wire would become stiff and brittle. Other times, in tight quarters, I would accidentally shrink my heat shrink tubing before I was able to pull it over the joint.
Then I tried a GOOD non-insulated crimp and never looked back. Crimping has made my repairs easier, quicker, and cleaner. I took a tip from Jafro when he did his DSM wiring harness and I fold over the tip of the bare wire to give the crimp more to bite and prevents it from pulling out. Another benefit with a proper crimp, you get both an electrical crimp and an insulation crimp. This helps prevent the insulation from pulling away from the joint. I've had insulation pull away from a soldered joint.
@dwb - Thank you for adding current information. I appreciate respectful professionals. My E&E (electrical and environmental) days were back in the 90's so it makes sense that methods and approved procedures have been updated. Sounds like I need to stop yelling at clouds and try something new and easier... but just as good.If done properly, either method can produce quality results.
Exactly this. Crimping forms a cold weld when done right.Copper gets brittle from heat, which makes the fine strands break easier just past the point of the solder. Not to mention it makes a stiff spot. You'll never find a soldered joint in an oem harness for a reason.
so i am not supposed to use my MAPP gas torch on 18ga wire?Don't just throw it up to 500F and go full-send making the joint hot enough to melt the insulation barely 1" from the joint.
So are we all against dollar store butt connectors then?
Not even if you're 23 and reinstalling a stereo because thieves.
Wait. That was me. Move along. Nothing to see here.
In all seriousness, I've actually had pretty good success with them for low power/non critical applications. That stereo is still bumping 20 years later.
However, they WILL pull loose if not careful and I think they are aluminum which can corrode with copper wire (Galvanic corrosion).
In case you want to go with a better crimp solution, here's a cheap but functional crimping tool
https://a.co/d/7bQ9fYX
I also use this Terminal Connerctor Kit https://a.co/d/6Fpt9PH
Edit: don't forget heat shrink tubing as well.
Don't threaten me with a good time.Guess I need better crimp connectors for my wideband's logging wire to the ECU then. Doh. May just solder it. I've been spending so much on the car lately my wife gently asked me how much more money of our savings I'm gonna spend on it, so I'll refrain from buying connectors and a specialty crimper. Already got the solder and soldering iron.
I'll solder without flux and with the butane end of my soldering torch just open instead of with a tip, just for @curt-s .
I worked on a 775whp Evo. We don’t know how it made that or how it ever survived.As long as you're not a twist & tape guy I can respect that
