2G GSX Connections
Thomas Mason
253
34
Apr 29, 2017
Covington, Kentucky
Attaching photos of a couple connections I found disconnected if anyone recognizes them and can let me know what all they are. Thanks ahead it’s 1998 Mitsubishi Eclipse gsx auto
Yea idk the whole sensor should be in the pic as good as I can get it.. it’s located under the intake manifold towards bottom of engine bay... closest description I found was a knock sensor maybe... but I’ve been told that would be farther down on bottom of block. To me it seems like the bottom and car seemed to run better after reconnecting it.
Located below intake manifold. Bigger connector connected to block. Knock sensor is closest description I could find
Anybody recognize this plug or sensor? had a ticking coming from it. Used a stethoscope to find it. Once source was located, found the red and green wires split and needing repaired.
