XC92
5+ Year Contributor
- 1,654
- 376
- Jul 22, 2020
Queens,
New York
A year and a half ago I replaced everything timing belt related, timing and balance shaft belts, pulleys, tensioners, seals, water pump, etc. I used an OEM TB and what I believed to be a genuine Gates Kevlar racing BSB. Everything ran fine afterward, but as a sanity check I took the cover off last summer while overhauling the intake & exhaust, and took some photos. Everything looked fine, timing was perfect, no oil or anything out of place, so I put everything back on and things have been good.
But just now while looking at photos I've taken over the past few years while working on the car, I noticed what could potentially be a problem. The timing belt looks fine, but the balance shaft belt just doesn't look right, like either there's a layer of crud on the teeth peaks, or the outer layer is delaminating. Now I'm wondering if I got a counterfeit and it's liable to come apart and destroy the engine.
Here's what I mean:
Does this look off? I bought it on eBay from MAPerformance for around $30.
And, if this is a bad belt, this job was long ago enough that I can't quite recall, can it be replaced without taking everything else off, especially the hydraulic tensioner? I'd hate to have to redo the entire TB job as it's so exacting.
FWIW here's what it looked like when I installed it:
Here's what I mean:
