Drag Race Build 1990 Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
GT40 Variant
Drivetrain
AWD
Build Type
  1. Drag Race
Mods-Engine
- 6 bolt Non Turbo Block
- Wiseco Custom Pistons with DLC Pins CR9.2:1
- R&R Aluminum I-Beam 156mm Long Rods with ARP L19 Bolt
- Eagle 94mm ESP Armor Crank
- L19 1/2" Head Studs
- SCE Copper Head Gasket
- Fluidampr
- MAP Stage 5 Head
- Kelford solid lifter cams 282/288
- Kiggly Racing Race Only Valve springs
- Kiggly Racing HLA Pressure Regulator
- Ferrea Competition Plus +1mm Valves
- HKS Cam Gears (Previous model)
- Tomei Timing Belt
- Garrett GTW3884R (GTW6765R) / T4 Open .81 A/R
- TurboSmart Hyper-Gate45HP Wastegate
- JMF T4 Top Mount Exhaust Manifold
- JMF Drag Intake manifold
- Q45 Throttle Body
- JMF 10 Gallon Fuel Cell
- -10AN Fuel Feed Line / -8AN Return Line
- Fuelab 42401 Prodigy Fuel pump
- Aeromotive Fuel Regulator
- FIC Fuel Rail
- FIC 1800cc BlueMax Low-Z Injectors
- Crank case vacuum pump
- Nitrous Kit
- Water / Methanol Injection Kit
Mods-EMS & Logging
- AEM EMS Series 2
- AEM CD-7 Dash Display
- Plex Knock Monitor V2
- PLX Wideband
- PLX EGT
- AEM 7 Bar
- AEM Oil Pressure
- AEM Oil Temp
- AEM Fuel Pressure
Mods-Drivetrain
- JNZ Tuning Short Shifter (Previous)
- Ikeya Shifter w/CO2 air shifter (Previous)
- KDN/Boostin Shifter (Present)
- PPG Dog Box w/ Quaife Front LSD / Boostin Performance 300M output shaft
- Boostin Performance 300M upgraded T-case w/ Boostin Billet Housing and Magnus Billet Cover / Jeff Bush Racing T-Case Brace
- Quarter Master 8-Leg Triple Disc Clutch
- Driveshaft Shop 1000HP Front Axles
- Driveshaft Shop 1000HP Rear Axles
- Driveshaft Shop Single Piece 3.25" Carbon Fiber Driveshaft
- 4 bolt rear diff with Frontline Lab Cover
- Feal 441+ Drag Spec Coilovers (Present)
- Koni Yellow with Tein S-Tech Springs
- STM Lightweight Front Drag Scalloped Brake Kit
- RX-7 FD Rims
- Hoosier Drag Radial
- Rota Slipstream 15x7.5
- M&H Racemaster Drag Slicks 24.5x8.5x15
- MOMO Race 350mm Steering
- Volvo S40 electro hydraulic power steering pump
  • Engine w: vacuum pump Oct.jpg
DSMPT
Comments
2
More in 1G DSM
Share this Vehicle
