2G Balance Shaft/Timing belt help.
DSMinAK
5+ Year Contributor
38
10
Apr 28, 2018
Fairbanks, Alaska
so my balance shaft sprocket doesnt want to spin freely by hand but it will turn fairly easy when I rotate it with a wrench, my question is what should I do next to fix the problem, and is it indeed a problem? (95 Eagle Talon TSI 7 Bolt)
Sounds like your BS is starting to seize. Drop the oil pan & inspect the bottom end. It sounds like you may need to plan a rebuild. How many miles on the motor?
Are you expecting it to spin? Or you have to really crank on it to even get it to move?
I thought the sprocket was supposed to spin freely, and it spins pretty easy but it wont spin by hand. Would rebuilding the balance shaft be a better option than putting in the balance shaft eliminator kit?
Spin freely as in apply force and it just keeps going? No. Turn easily by hand as on nearly no resistance, yes.
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
