1G timing belt kit for balance shaft elimination
91_gst
Dec 2, 2014
Taylor, Michigan
Im doing a balance shaft elimination on my 91 gst and I was wondering if I needed any special timing belt kit since there won't be a balance shaft. Thanks for the input
The front balance shaft is driven off the belt, the rear balance shaft is internally gear driven and will have to be removed with a stub shaft installed in its place. If you do not remove the rear balance shaft you will have bad vibrations and it can lead to bolts backing out or even clutch or trans damage over an extended period of time.
Use the grooved OE stubby shaft or a cut down/race shaft on the rear shaft.
If you do the BSE in car, install the stubby or race shaft in the rear, Leave the front one in place, once the front cover is back on, install the spacer and gear and no belt.
It is a chore to remove the front shaft and flip the bearings with the engine in the car.
Well its getting rebuilt at the moment with the bse kit. I was jw if I needed a certain kind of belt. Thanks guys
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
