Please Support Rix Racing
Road Race Build Journey of an auto Time Attack car
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Turbo Type
16g
Drivetrain
FWD
Automatic
Build Type
  1. Road Course
* Fueling...
FIBA custom flat bottomed fuel tank/cell W/ multi shut off balls, vent and breathers ~ Holley Hydra fuel matt ~ Window fed quick fill system ~ Dual DW350 IL fuel pumps ~ Coolant swirl pot ~ 8AN feed lines - RCI 10 Micron SS fuel filter ~ RCI fuel rail ~ FIC Hi Z 1200cc injectors ~ Radium engineering multiport AFPR ~ 6AN return lines.
* Interior...
90% ish interior delete ~ Flocked dash and center console ~ Driven flat steering wheel ~ RR engineering quick release hub ~ NGR hub adaptor (nasty hub) ~ full roll cage (to be redone) ~ OMP and Mirco GT bucket seats ~ Titon 6 point harnesses ~ FIA regulated fire suppression system ~ Custom ABS door panels ~ Alloy panels for displays and cut off switches.
* Exterior...
Full Time Attack body work made mostly from alloy ~ fully ducted intake from bumper out the hood ~ Carbon, Kevlar, Fiberglass vented hood W/ 4 quick release catches ~ air directing wide arch panels and side skirts ~ rear diffuser ~ formed rear poly window ~ poly side windows W / window slider and cooling duct ~ Chassis mounted aero foil mount ~ DJ engineering SM132 aero foil by Simon McBeath.
* Other bolt on's...
Avid billet auto trans mount ~ Torque solutions timing side billet mount ~ Galant 90amp alternator.
Mods-Engine
* Engine block internals. 2.0 LR spec...
Stock 2.0 block with 7 bolt oil jets ~ Molnar 88mm Billet Crank ~ CP Carrillo H beam 156mm rods W/ Carr bolts ~ Custom CP Stroker pistons 9:0.1 W / 3x coatings and thicker DLC pins ~ King rod/crank bearings XP coated ~ Balance shaft deletes (BOTH) ~ ARP mains stud kit ~ Volk SS pilot bush.
* Engine block add on's...
Frontline Fab billet oil pump W / race filters ~ FIBA Modified 7 bolt oil pan / Baffled ~ Kiggly Racing V3 trigger wheel kit 12 - 1 wheel ~ Fluidamper pully / ARP crank bolt ~ Kiggly racing diamond shims for crank and flexplate.
* Cylinder Head...
Mild port / smoothing and full deburr inside and out! W / smoothed bowls ~ Oil port mods ~ Engbldr stock size SS valves ~ GSC Valve guides ~ supertech viton valve stem seals ~ Kiggly Racing HP beehive valve springs W / TI retainers ~ GSC S2 Billet cams ~ GSC zero tick lifters ~ Kiggly Racing HLA ~ SCE vulcan cut ring head gasket ~ ARP L19 head stud kit ~ TMZ head stud load spreader inserts ~ OEM mitsu ALL NEW gaskets/parts where required ~ Skunk racing PRO lightweight cam gears ~ Toda Racing Kevlar timing belt ~ Frontline Fab Billet V1 valve cover.
* Cylinder head externals...
* INTAKE side...
Apex'i super intake filter ( Enclosure ) ~ FIBA SS intake pipe ~ Treadstone TR8 intercooler ~ FIBA SS intercooler pipes ~ HKS SSQV 4 bov ~ EVO 3 60mm throttle body ~ EVO 2 intake manifold.
* EXHAUST side...
Forced performance Race manifold ~ Hybrid 16G / Clocked ( KTS billet 7x7 compressor wheel, upgraded internal thrust bearing package, race Inconal 718 9 blade high flow turbine wheel ~ Forge Actuator w / 20PSI spring ~ Modified o2 housing now for EGT bung and V band ~ FIBA 2.5" DP - 3" exhaust system Straight pipe to central raised exit.
* Exhaust heat management...
Ceramic coated manifold and turbine housing ~ FP manifold blanket ~ FP heat shield (modified) ~ Turbine housing blanket ~ wrapped o2 housing ~ custom ALT heat shield.
* Ignition...
Stock coilpacks ~ NGK spart plug wires W / thermal barrier / arc sleeving ~ NGK BPR7 plugs.
* Cooling system...
Custom radiator core crossflow ~ Davis Craig EWP150 water pump W / display ~ Frontline Fab stock pump block off plate ~ FIBA coolant swirl pot (head outlet) ~ FIBA coolant overflow can ~ Dual hi flow fans 1350 CFM ~ pure distilled water W / 5% coolant and Water wetter ~ Fully ducted system - HKS 1.1 rad cap.
* Oil...
Fuch's Pro Race S ester oil 10w50 ( Race ) or 10W40 ( Winter ) ~ setrab oil cooler / 10AN lines ~ (1st inline) Calan VS3 catch can modified for volume only ~ (2nd inline) FIBA dual baffled and filtered catch can ~ all 10AN lines.
* Full PS delete.
* Full AC delete.
Mods-EMS & Logging
* ECU...
Dsmlink v3 full ~ SD GM W/harness ~ 4 bar omni map sensor ~ IR boost control solenoid.
* Logging DATA...
Innovate lc-1 A/F kit ~ innovate mtx-d boost gauge ~ innovate mtx-d oil pressure/temp ~ HKS type 1 turbo timer with all warning functions ~ mainline sensors auto trans temp sensor and intercooler air temp kit
Mods-Drivetrain
* Transmission...
Quaife ATB diff ~ Translab shift kit/valve body ~ modified trans pan ~ Cartek digital gear indicator / shift lights - morrison fabrications lower auto shift cable brackets ~ Racing trans temp sensor and gauge ~ Setrab trans cooler ~ Redline D4 ATF.
* Transmission contol...
Road surge V3 shift kit W / big display ~ Track formula 8 channel wireless carbon fiber paddle shift system.
* Wheels...
Konig Hypergrams 18x10.5 ET25 ~ (RACE TIRES) Pirelli Trofeo R 295-30 ~ (ROAD TIRES) Veredestein Vorti+ 275-35 ~ Project KICS R40 lug nuts.
* Brakes...
* Front...
FIBA Motorsport anodized 6 piston radial mounted race calipers W/ AKB springs ~ FIBA 360mm fully floating 2 piece race slotted rotors ~ Gloc R10 brake pads ~ Millers 300+ brake fluid.
* Rear...
Stock EVO rear Brembo's W/ Stainless pistons ( soon to be removed for the FIBA rear caliper kit ) ~ comline 1 piece race slotted rotors ~ Carbotech XP8 brake pads ~ Millers 300+ brake fluid.
* Brake system parts...
Custom floor mounted Dual master cylinder pedal system W/ balance bar - Bias control ~ Dual Tilton master cylinders ~ Tilton 3 chamber res chamber ~ Tilton rear lever prop valve ~ Full chassis stainless brake line kit front to rear.
* Chassis / suspension...
* Front...
Fully tubed nose end of chassis ~ OEM front lower arms (soon to be FIBA arms) ~ Hardrace front compression arms (soon to be FIBA arms) ~ FIBA tubular front upper arms ~ FIBA V2 bump steer kit ~ FIBA adjustable drop links ~ FIBA/Quaife Quick race rack and pinion kit ~ DCE pro street EPAS kit ~ FIBA front tubular RACE subframe - 4 point brace - front crossmember - billet arb brackets ~ OEM ARB.
* Rear...
FIBA tubular lower control arms W/ adjustable droplinks ~ FIBA trailing arms ~ FIBA tubular upper arms W / Roll center adjustment ~ FIBA adjustable bump toe arms ~ FIBA (LIGHTWEIGHT) T45 tubular FWD subframe ~ FIBA EVO arb adaptor brackets ~ EVO 22mm ARB.
* Coilovers...
Modified BC racing coilovers W / spherical bearing upper mounts F/R ~ 4Lbs Helper springs F/R ~ F spring rate 672Lbs / R spring rate 784Lbs
* Extras...
Modified OEM front axles ~ Modified EVO 5 wheel bearings W/ ARP wheel studs ~ Modified front Galant knuckle ~ Modified rear AWD knuckle ~ Modified EVO rear wheel bearings W / ARP extended studs ~
Parts Wishlist
* Actual wish list is a drysump setup, redo the rollcage to allow a halo seat to be used,
* I would like to do a rwd conversion with a new age evo block converted to inline with a trans adaptor for a seqential gearbox possibly R154
* Ecumaster ecu / pdu and dash display
* BC ZR coilovers
* 4 or 6 piston racing caliper rear brakes customised with spot calipers and custom backing plate
* Make more custom body panels / molds
1/8 Mile E/T
0.000
1/8 Mile MPH
00.000
Dyno HP
175 whp
180.1 lb/ft
Dyno Type
Dyno Dynamics
Dyno Sheet Photo Link
Dyno Shop Name
power engineering
Dyno Session Details
Fuel Used : Pump gas
Turbo : T25
Boost : st
Videos
EC17PSE
Comments
17
Rating
4.89 star(s) 9 ratings
More in 2G DSM
More from EC17PSE
Share this Vehicle
