JusMX141
Moderator
- 15,147
- 1,292
- Dec 13, 2005
Greensburg,
Pennsylvania
Interesting you said that, considering the winner of the Bracket 1 class at the 2009 DSM Shootout was Holset-powered by a turbo that I rebuilt. That means that out of all the 12.99 & faster cars which entered that class (DSM or Evo), no matter what was bolted to their manifold, Dave beat them and took home the first place trophy.we should have a holset vs all other turbos class at the dsm shootout.
He also did this with completely blown-out front struts, and a stock 6-bolt with 139k on the ticker. The struts were so blown that he actually contemplated not running the car the day before the race. I'm glad he changed his mind.
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/WHmMdqEekOE&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/WHmMdqEekOE&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
Anything you'd like to add?
. Then results on dsmtimes.org with the hx50/55 hybrid with race weight similar to a full weight awd 1g. So since this isn't YOUR thread, help answer the OPs question about the hx40 or 6262. You can always leave if you don't have anything to contribute. You brought up a question about a holset turbo that barely is on the upper end of the OPs range and you got an answer backed with proof. If you want to see an example of how to assist and properly reply to a thread, see mine and the other wisemen's responses. No fluff; all data backed by logs dynos, 1/4 results, and proof of said dynos, 1/4 results; with sincere effort put into staying on topic.
. So for 200 dollars + 250 for the hotside he got a SICK SICK turbo!
that's going to be laggy, but you're not really seeing how small the wheels are inside. The compressor inducers arn't huge, nor are the turbine exducers. The spool thing is reasonable considering how much a difference in the inducer-exducer measurements are (much more efficiency: so less energy is converted into more boost earlier). Whats amazing is how much it flows considering how small the wheels are, how much of a difference in the diameters, and how long the tech has been around. The hx40 has been around since 1994 (They were still building 14b powered cars then!!!!).
