bastarddsm
- 5,776
- 1,710
- Aug 26, 2003
Mendota,
Illinois
Lol, where did the op say that he blew his up, I can't find it. I only mentioned guys that made good power on the .55 for example to show that the op's goal of 400-450 on pump isn't some lofty unattainable goal - it's do able, been done many many times, and if they are blowing them up at that level it might be time to reevaluate the setup. Like I said maxed out it's a 7-800hp turbo, running it at 400-450 is hardly working it. And I also mentioned it to reaffirm that it's not some "crappy" combo that can't perform, because they clearly do, it's clearly not the right combo for max power, but neither is anything bolt on. The bolt on 40 is a compromise between spool and power - there might be better ones, but to say that it is "crappy", especially when you have not used one is flat out ignorant. For the record, I've not said any of them were crappy/bad/junk/ect. And yeah I still think a red will be a downgrade. It's a smaller turbo, with a smaller hot side, and a smaller shaft. It's going to be run closer to the max to make the same power, and the upgrade future is basically 0. Stay with the hx, decide you want better power, do an open t3, want better power and good spool, do a divided t4 setup. Want even power power, swap the turbo, since you already have a good hot parts kit. Same thing goes for the zero. Spend $1500 bolt it on, that's it. Decide you want more, sell it for half, maybe, buy a whole new setup - turbo and hot parts..
But just to clairify something, a bolt on hx35 will work, but a bolt on 40 is a crappy combo?
I think you are also putting words in my mouth, I never said the fp stuff won't run and wont last. They really do run good, but try and crank up a tiny little red to what a real hx40 setup would do, and see how long they last. There are no shortage of guys complaining about reds/greens/blacks coming apart. Jeez there for a while all the classifieds were full of blown reds greens blacks 68hta's ect. If they were soo good there wouldn't be so many little turbo shops rebuilding them. It's a thing that happens, big wheels, little shaft, small housing, max power it's a time bomb. Put a hx40 wheel in a 35 in a .55, try and make all the power and yeah it's gonna come apart too eventually.
The HE has a tiny little volute, and I did terrible things to it. Even now the last time I ran it, it had a chinese HX40 turbine in it, and it stayed together - didn't pick up any power though (tells me th is restrictive like a bep bolt on) For those that don't know I was using it on a turbonetics manifold, and it takes a lot of careful clearancing to make it fit. At one particular time I was impatient and screwed up, forced it together, and it make the chra not sit in the TH right. Turbine wheel was rubbing the housing, I ran it like that for a long time without knowing, still stayed together.
What were you trying to do to it? Was this still your 10.5:1 motor? Pump gas and trying to run big boost? .
Standing by for you to take things out of context and try and spout more garbage you don't know. Meanwhile I have the fastest HE351, HY35, and like 3rd or 4th fastest HX40 (even though mines smaller) on a DSM. How many 60mm turbo dsm's are faster than mine? About the only ones are pretty well strict race car's So how is my opinion not valid and yours is? I guess if I wanted to be on team slow I could take advice from you.blah blah blah
Idk. I suspect the tune was mostly to blame, lotta EGT's or something. Maybe you had 2 bad ones. We get usually these things used, and have no idea what's been done with them. I had a big power duramax pull truck here that went to a new $6500 harts turbo. 2 passes turbine came apart. I have a basically identical truck here too that ran that turbo and has a couple seasons on it. They warrantied it, and it's been good since. Some times it sucks to suck I guess.It wasn't operator error that broke MY Holset shaft Kurt, it was just to much heat in one little hole.
