Road Race Build Ludachris's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
GT30 Variant
Build Type
  1. Road Course
FP3150 turbo (dbb 50-trim with FP30 housing), Tial Wastegate, ExtremePSI Race FMIC, DSMLink, 850cc FIC injectors, Walbro 255lph, Aeromotive A1000 AFPR, full -6 SS braided fuel supply line, Setrab oil cooler, '90 oil filter housing, Thermal R&D exhaust, FPrace exhaust manifold, Megan downpipe, PWR custom aluminum radiator. Recaro Pole Position seats.
Mods-Engine
2.3L stroker motor, Unorthodox cam gears. CNC Ported race head and 2.3L stroker block from Jackson Auto Machine (JAM), JAM cams, new valvetrain hardware, ARP head and main studs, cometic head gasket, Eagle rods, Wiseco pistons, 2.4L crank.
Mods-EMS & Logging
DSMlink, Innovate LC-1 Wideband O2 gauge, Defi oil pressure, fuel pressure, EGT, boost gauges, Autometer oil temp and water temp gauges.
Mods-Drivetrain
ACT Xact Flywheel, SPEC Stage 3.5 clutch.
17x7.5 Kosei K1 wheels with all season tires, Ground Control coilovers, Koni shocks, Whiteline 22mm front swaybar, 26mm rear, TCE FSL Road Race brake kit (4-piston). 17x9 Team Dynamics wheels with 27mm offset and Toyo RA1 255/40/17 tires for the track. These wheel/tire combo didn't rub on the suspension but it didn't tuck inside the fender either. Flares are necessary, or a higher ride height and stiffer springs like I ran.
Parts Wishlist
Sparco steering wheel, roll bar, Stack dash panel, Volks or SSR wheels for the street, Wilwood pedal/master cylinder set, new paint, and lots of custom fabrication.
Dyno HP
435.0 whp
399.2 lb/ft
Videos
DSM's on Pass Time
Originally posted in the videos forum.
Ken Davis' 1000 hp 97 GSX
Sorry Ken, had to post it for testing purposes.
Hill Climb DSM
Very cool. Just found it on Youtube.
Ludachris
Comments
4
Rating
5.00 star(s) 6 ratings
More in 1G DSM
Share this Vehicle
