dwb
- 1,571
- 1,089
- Sep 9, 2021
Broomfield,
Colorado
My valve cover tends to leak along the front side of the head. No matter what I do, I always find a bit of an oil leak coming from the valve cover gasket area. Sparkplug wells are dry. I have all original OEM hardware, no stripped bolt holes and original valve cover. Sealing surface is clean and no gouges.
I've tried several new OEM gaskets, no RTV except for the aluminum half moon (which isn't leaking). Initially I install the bolts with a hand driver, just snug. Then I gradually tighten them over time (months) to see if I can get it to seal. I eventually end up splitting the gasket because the bolts get over torqued.
I've ordered another new OEM gasket and will give it another try, but what's your trick to getting it to seal up?
