What Turbo is this? [Merged] Turbo ID Identification
the first look looks like a 1g auto turbo or possible a 9b
it looks like a 16g
im starting to wonder if i have a garrett t28 on my car
I hit fuel cut soo I did a boost leak test had a few leak and fixed all but the BISS and injector seals. They are both very small leaks but im still hitting fuel cut and from what I've read is almost impossible with a t25 unless a line is disconnected. Is their any way I can tell if I have a garrett t28 with out counting the turbine wheels?
Their also different casting marks in my turbo and some of the pictures of t25s I've seen.
Yep t25. If it was a t28 you wouldn't be able to see where the fins on the compressor wheel neck down. the best piece of advice for identifing t28 goes as follows. 11 fins on the turbine = t25, 10 fins on the turbine = t28, and 9 fins on the turbine = fp big t28. Turbine is the hot side so you will have to remove the o2 housing to check.
Do a boost leak check. More than likely you have a leak. If you are too lazy to do one atleast tighten all your connections.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
