JayRolla's Talon TSi AWD
Eagle Talon TSi AWD
Port/Polished Evo3 16g @ 30psi, 3" Dejon Intake, 3" K&N Cone, 3.5" GM MAF Blowthrough, 1g crushed BOV, Large 24"x12"x3" FMIC w/ 2.5" Piping, Heavily Ported SBR Exhaust Manifold, Heavily Ported Evo3 o2 housing, 2.5" SS Turbo back exhaust w/no cat & 2.5" Magnaflow Street Muffler, Koyo Radiator, Stock fan w/ 1600cfm slimline, NGK wires w/br7es(.024). Fuel: RC 1200cc injectors, 255lph Walbro
Mods-Engine
Rebuilt 6 bolt swap w/ New rings, rod bearings, main bearings, Decked/Honed block, 88mm crank, 1g big rods, 2g pistons, removed balance shafts, front facing oil filter, Rebuilt Head w/ New guides, valve seals, cam seals, valve cover gasket, MLS head gasket, 3 angle grind on valves, resurface, intake mani gasket, exhaust mani gasket (3 layer EVO III), Greddy Kevlar Timing belt
Mods-EMS & Logging
ECMlink v3 w/gm maf integration, non-eprom ecu conversion, AEM UEGO WBo2, Palm iiic, MMCD, Boost gauge, FP gauge. E85 (best thing since Dsmlink).
Mods-Drivetrain
Jacktransmissions.com built tranny w/ double syncroed 1st, 2nd, torrington bearing, 4 spider gear CD, New Shift Forks, hubs, sliders, springs, shoes, reset bearing preloads. Machine Balanced ACT 2600/ceramic 4 puck unsprung, Fidanza Aluminum flywheel. 4 bolt rear end, Polyurethane Motor/Tranny Mounts
Eiback prokit springs, kyb GR-2 front, agx adjustable rear, 16" enkei wheels, S3800 ZR tires, 2 Piston Calipers
Parts Wishlist
SOON HX40 AT 35PSI ON MY STOCK LONG BLOCK!
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Sponsored Car : no
335.1 lb/ft
Dyno Type
Dyno Dynamics
Dyno Sheet Photo Link
Dyno Shop Name
Revolutions Performance
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : E85
Turbo : Big 16G
Boost : 32
JayRolla
More in 1G DSM
Share this Vehicle
