What did you do to your DSM today?
Had big plans to work on the wifes 1g build today… wake up and see its -4 outside in tropical ohio.
Over the summer i meticulously shortblocked the engine, got the head cams pan on and sealed up. Began to route the tbelt and pulleys and then 237 other projects came up.
One day here im gonna finish the accessories and get engine to the other garage. Get ready to slip it back into the gsx for her 👍🏻
Should be a good running little toy. She wants to auto cross it.
Ill add to the build sheet sometime here. Probably been 2 years or more since ive been on tuners for anything!
Tore apart all my brakes, put SS brake lines on the front, will be doing the rear this weekend and putting drilled and slotted rotors on front and rear with 94 dual piston calipers on the front
The irony of it being -4 in TROPICAL, Ohio haha
I need to build one also. I'll go back and see if I can tell what you made it out of. Looks Hella easy to install the power train with ONE MAN!
It's all 1x1 tubing, some 1/8 plate in the corners mounted to some $20 Amazon casters and a little 1" flat bar that I made the mounting points out of. Side note, the rear trans side mounting point needs a spacer as it sits back from the edge of the block, I used my broken wrist pin for the spacer LOL
Thank you Jason. It's on my list now. You sure showed us all how a "Pro" does it :thumb:
Ran new, better, proper colored wires to the AEM water temp sensor then promptly hid them with 3M 33+ electrical tape. LOL
After that I temporarily hard wired the speed density stuff in to get rid of a janky plug while waiting for my ecmlink harness and rywire 1g MAF pigtail. Fixed the random stutter/stumble I was having. Turns out the random lean issue and random stuttering was due to the pos eBay harness plugs sucking/vibrating and the sensor becoming unplugged/reconnected with engine vibrations.
So. Pretty good day. Also disconnected the boost controller and I’m running it straight wastegate pressure again until the clutch is fully broken in.
Made a heater core tester out of some quick hardening epoxy and an air compressor fitting.
New core is holding 30psi and no bubbles.
So where is that coolant leaking from??? 🤦
Picked up a Rotora BBK, a clean VRSF intercooler and some upper control arms with good joints. Mine were shotttttttt
Replacing the spark plugs on my 1g and also checking how many spare spark plugs I have. I realized that I still have some BR8ES.
Took some pic for comparing. You can see how come usually #9 is not good at long idling or on street.
BPR6ES - BPR7ES - BPR8ES - BPR9ES
NGK Racing #8 - BR8ES - BPR8ES
This weekend's project was stripping the back half of the car for cleaning, powder coat, poly bushings, 4-bolt swap, fuel upgrade, etc.
Got around to finishing the brakes, front and rear. My god f*** the rear calipers though LOL Glad I got it done. ‘94 dual piston calipers and singles in the rear. Drilled and slotted rotors all around. Gotta get the transfer case rebuilt, want to throw a resonator and vibrant muffler on as well as some other things and eventually paint it
fixing the bugs of this turd
and raising boost slowly i was doing some short pulls to check parameters and i got 40lbs min from the 75 goal im planning need to put a better tach or a reliable upshifter for my trans so i dont shift early i was doing at 6k 6.3 when i shpuld do at 8500
Finally got around to doing some much needed rewiring. Cut off the old janky 2G MAF plug that would read "unplugged" in ECMLink when jiggled, with a great looking OEM 1G plug with nice soft wires. Soldered in, double walled 3:1 marine grade adhesive lined heat shrink, OEM Corrugated tubing, and 3M Super 33+ electrical tape on the ends and over the soldered section.
From there I un-fooked my gauge wiring and installed my AEM Tru-BoostX. So happy with it.
Finished it off by going back to the OEM weighted leather shift knob I have and cleaned it up/used some leather conditioner a detail friend gave me. No idea what it is, but it dried super nice. The leather boot feels soft and supple, and the shift knob is not greasy or etc. It's not wet in this picture, it's just that shiny. I could've gotten deeper/more thorough but eh, I'm happy with it.
Got most of the interior reinstalled. My carpet definitely turned dark blue after giving it a bath to get the coolant out of it. I'll pull it and give it another coat of black carpet paint in summer.
I also did some weight reduction. I think (hope?) these 2 completely different bolts are from the bracket which secures the heater core to the heater box. My heater core didn't fit into the bracket so it's not being used.
  • Wanted 1g 6 bolt rear timing cover tins both sides.
    6 boltRear timing cover tins.
    • Robert503
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted 2g WTB: 2G Eclipse GSX / Talon TSi AWD (1995-1999)
    Looking to buy a 1995-99 AWD Eclipse GSX or Talon TSi — running or project, rust-free bones...
    • Total Eclips3
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
