pauleyman
DSM Wiseman
- 11,604
- 5,468
- Nov 19, 2011
oklahoma city,
Oklahoma
Is it an oem master and slave? Did you check the diameter of the slave?Flywheel and clutch setup on. Put transmission on and fork was a bit biased left of center. ACT Streetlite, fidanza v2 6puck and pressure plate, comp clutch forged fork, new OEM pivot ball and TOB.
Fingers look correct, just slightly convex, unless there's something I'm not seeing.
Clutch fork isn't bent. Flywheel is .609 all the way around.
Perhaps the disk is just a tad thick and needs to wear in a bit but I'm considering a shim between .7 and 1.1mm. three aftermarket parts that are all determining fork resting position, the variances could be adding up to just aint quite right.
In theory....
. I said you better now its all been done haha i did not do all this for it to sit about the place
