Tire discussion and choices [Merged 11-7] which size what tires tiretire
would a set of 245 50 r 16 be to wide? on a stock offset rim
He said stock offset, not stock rim. And like mentioned before get a 8" or 8 1/2" wide rim if you're gonna put that wide of a tire on there. I had 7" wide rims and was running a 225 and that was about the widest I would go on that size rim. I now have 8 1/2" wide rims and am running a 245 with a +35 offset and they fit fine with minimal grinding of the trailing arm in the rear.
For your size wheel, i would suggest a 215 for the 6" width and for the 7" a 225 or 235 at max.
Im trying to run 38mm on my EVOX rim and i have to cut off a good 1/4 to 1/2 inch off the control arm in the rear to get it on. Plus it sticks out a good 1/4 inch at a minimum.
James :dsm::talon::laser:
I'm getting some 18" Enkei Evo 5 Rims. It's the right bolt pattern and it says it's a 38mm offset. Will that be okay? And for tires what should I be looking for. The rims are 7.5". I don't know size tires I should be looking for? What would be best for my GST?
Sorry, I just re-read your post, and realized you probably got these for a good deal. What type of suspension do you plan on having in the future? On my old eclipse with a stock set-up, on 18x7.5 I rubbed in the front when going around hard corners, or over big bumps with 225-45-18. Sometimes tire brand makes a little bit of difference in sidewall, that being said the tires were Kumho Ecsta ASX's.
I am getting 7.5 because that is all they have. I will be running on a stock setup for now until i get some eibach springs and shocks in the near future. Also, the options of tires they show me are 225/40/18 and 215/35/18. Any Preferences?
Between the two, definitely the 225/40/18. With a 35 series tire you will be feeling every little pebble in the road, too little sidewall IMO.
hey I have a 15x8 rim. Im looking for a good drag radial/ slick. What tire size will I be able to run with this setup. I was looking at 235/60/15. I have megan springs and agx's. Will this work or should i go bigger? Any advise?
Also, any good dr/slick that works good on the street/track? Thanks
i'm looking to do the same thing 15x8 (rota slipstreams) for my laser but just the front wheels. From what i've search on other threads the wheels should be +40 offset. I'm looking into Mickey Thompson ET street radial II or BFgoodrich Drag radial, both come in 225/50R15. If i go slicks MH has 8.5/24.5-15.
I was looking on doing one of those drag radials also. But im looking for a 235/60/15. Any one have pics with this tire on their 1g?
I have 16x8's on my 1g with 245 50 tire
Any Pics?
This is my friend's car. It is sold already And I can't tell you the size, but I think he ran 26x9.5/9.0x15 Rota slip Streams with some spacers.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
