Tire discussion and choices [Merged 11-7] which size what tires tiretire
I would love my car to sit like that. Try and find the specs on the spacers if you can.
The rims im getting only come in 15x8 or 15x10 and thats too big. So I could do a 15x8 with a P235/60R15 = 26 X 9.50R15. Would that fit a 15x8 rim?
Hey guys, quick question. I have done some research and have not found any difinitive answers. I recently picked up some sport max 009 rims. These wheels are 18x7.5 with an offset of 40. These wheels will be going on a 1992 Talon TSi AWD. My plans will be to lower it about 1inch to about 1.5 inch, so not too low. I plan on have a slight negative camber to help with autox. Anyways, this car will be used for mostly autocross and some drag occasionally. I have been told a 235/45 tire would be good. I was wondering if I should go with a wider tire like a 245 or 255. Also how much difference would it make if the tire was a 40 profile instead of 45. What tire size do you guys recomend.
240 seems like a good range being AWD, you don't have to go crazy wide.
Shorter sidewalls will look better on 18"s dropped, 45 would probably look nice. I think stock is 50 or 55.
225 40 r 18 for example means the tire is 225 mm wide, has an aspect ratio (that is, the height divided by the width) of 40% z rated is anything over 186mph
Q – Up to 99mph V – Up to 149 mph
R – Up to 106mph W – Up to 168 mph
S – Up to 112mph Y – Up to 186 mph
T - Up to 118mph Z – (See Below)
H - Up to 130mph
I wouldn't go larger than 235 on a 7.5 inch wheel if you're looking to auto-x, my $.02. Also, it goes tire width (235) height as a percentage of width (40), so the tire is 40% of 235mm high, I believe the z is speed rating.
Hi can someone tell me if you can put a 225 55 17 on rear of 1998 2wd TAlon without spacers or rubbing?
225/55R17 is gonna be a bit tall, It's hard to say if it'll rub or not. what's the wheel width and offset?
I think the rim is 17x7 it has 225 40's now, there "Fast" rims but not sure on offset? Not worried bout fenders ..think I'm ok there it's the curved arm behind tire, that gives me concern.. but I guess if I have to I can go with spacer's.. I bought them because good deal / top of line Hydro Edge Micilens wish they were 45's :( anyone in Ontario has some 225 -45's or 235 40's they'd like to trade I'd give 3 for 2...LOL....
without knowing offset it's really hard to tell. I know my 235/45R17's on 17x8 with a 38mm offset are really close, maybe a couple mils of space tops.
K well thanks I just dont want to pay to put em on then find out after I need spacers.. If I need em I'd like to get them 1st that's all...: or maybe I'll just re sell em and get 45's decisions-decisions LOL
I need a taller tire myself. I have a set of 205/40/17s on there now and they are like rubber bands which create this awful gap between the fenders/tires. I always go on tirerack and configure things there when it comes to trying to fit tires/wheels on cars. It isn't the best way I'm sure, but it helps me get to the answers I'm seeking regarding these issues.
Tire Rack - Your performance experts for tires and wheels
Lol yep thats what on front.. they were deal too :) the 55's will deffinatly fill the back if they fit ....
Are you running on stock suspension or do you have it lowered any. I'm about to run 225/45R 17's on 17X7 with a 38mm offset. Thanks
Stock at moment but it goes in for coil overs and struts next week.. the more I look at it I really don't think the 55's are gonna work .. at least not without spacers.
You'll have plenty of room, you should be able to drop it 2-3" without worry. My 235/45r17x8s would require a little rolling of the fenders to go farther than a 1.5" drop
Im planning to order this rim:
18X7.5 5-114.3 45S
with Nitto NT NeoGen ZR
235/40ZR-18 XL 95W B
Here's a simulated picture of them on the car:
What do you guys think? Ever heard of these rims? I have stock suspension.
Yay or Nay?
Thanks for the feedback I respect your opinion... I don't expect everyone to have the same taste.
But I would like to know if anyone has heard of the Rage brand. I think they are an exclusive brand to Discount Tire Direct.
Another I was looking at was this Momo one:
Black:
or Silver:
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
