Calan
DSM Wiseman
- 7,250
- 400
- Jan 16, 2007
OKC,
Oklahoma
Going with what was said by Calan and using the tire calculator. It shows that the 235\40\18 would be extremely close to your prior tire size. So the rubbings that you have now, if any, would probably be the same with the new tire...I believe.
Yeah.. they're close. The 235/40/18's are a bit taller, but not much. But then again, it may not take much to rub.
I mentioned 235/35/18's because they would be a bit shorter and give a little margin of safety, at least height wise. You still need to check the offset though to avoid rubbing because of the added width.
Either way, you have very little side wall on a whole bunch of rim ... hope you don't have to deal with speed bumps often
