laserboost
- 98
- 0
- Jul 10, 2004
bitch,
Illinois
It's basically 2 wires, power and ground. Find a power source and then ground the other wire, it's not very difficult but it's tedious and annoying to do.
1.8Lof94Eclipse said:Read the specs on the web site. There's a cpu that controls the light. I think you can program it or have it sync with the music.
nutshot said:Sorry, I thought the vid was a different set of lights. The site in the first post has the detail on controller that I wanted to see, but is it the same for the Brittish vid?
cuttheduck said:Tell you friend to install them right.
Being an led kit you have to point the tubes out from the car. Pointing them straight to the ground obviously results in nocoverage and looks crappy. All led tubes that I know of are able to turn the lexan part of the tube indepently from the base. There usually brighter then neon, they just dont underglow the area directly under the car as much but kick out an easy 3-5 feet from the sides.
