wret
- 2,931
- 91
- Jul 3, 2003
Bel Air,
Maryland
You wouldn't hear the motors if the switch was off. Are you sure you didn't switch them and they are properly installed with the gears engaged?
You can test them when removed by energizing them and testing the resistance by holding the gear with pliers. It has a LOT of torque. If not then you either didn't install the pins properly or something else has failed, but I have not experienced any motor failures except the pins.
