DreamChaser7
Supporting VIP
- 1,282
- 1,668
- Jul 18, 2019
Valrico,
Florida
I’m so jealous for real. Can’t wait to get to the point you’re at. Great job, looks amazing, keep it up!
. My auto harness didn't have the reverse switch plug in the harness. The auto transmission doesn't have the reverse switch like the 5speed does. I never wired in the reverse switch since my harness was already re-done, and it was an oversight when I originally did it.Automatic cars don't have reverse lights?
Mind sharing the link to the ebay lip?So had some time at home this weekend to start on the engine harness. I wanted to do it right-ish. I'm not buying new pins, or the special tool or any expensive loom, but I am de pinning and running each sensor independently to the ECU/ Dash area. Fixing any nicks in the wires, and replacing any damaged connectors.
I started by de-looming and de pinning every connector, labeling as I went.
View attachment 702155Untitled by bradydings, on Flickr
Pretty simple, just time consuming and you need to stay organized. I simply numbered the ECU pinouts with their respective numbers. When I came to any junctions, I just de-pinned a connector and labeled that wire "TO MDP" or "TO TPS" etc. Pretty straight forward. I'm looking forward to simplifying the harness ground and power. It is also crazy how much extra wire is in the loom. Seems like they ran wires 10 foot long that only needed to go 5 inches etc.
View attachment 702156Untitled by bradydings, on Flickr
View attachment 702157Untitled by bradydings, on Flickr
Once I had all the plugs separated, I started laying everything out. Starting with the injectors, then knock, CAS, TPS, COIL, etc. Making sure I have plenty of slack/strain relief.
View attachment 702158Untitled by bradydings, on Flickr
View attachment 702159Untitled by bradydings, on Flickr
View attachment 702160Untitled by bradydings, on Flickr
Once I have it routed like I want it, I will tape the bends tightly, to keep their shape, then remove the whole harness and finish it up on the table. I'm putting the injector resistor plug, the main fuse connection plug, and the transistor under the dash.
I also got a new ebay lip. They definitely have gone up in quality since they first came out 5 years ago or so, this one is thick, and not as flimsy as previous ones.
View attachment 702161Untitled by bradydings, on Flickr
Peace!
. Definitely how you plan for a new build to go. I've always had really good luck with the UV dye to detect oil leaks. I had something similar that was incredibly difficult to find and it helped identify that a cam seal was leaking which caused drips to come from multiple areas toward the bottom of the engine.Well... feeling pretty defeated.
Oil drip found under the timing cover, oil drip found on the OFH, oil on the turbo return line, oil leaks below the exhaust manifold, cannot pinpoint it down but could be coming from anywhere really.
1G water pipe I bought that supposedly was already welded up with water bung deletes, that I got powdercoated, leaks.
I've never had this car leak free, and I cannot drive it even with the tiniest of leaks. All gaskets, seals, bolts everything were brand new, just so defeated and really bummed out.
Yeah I need to pull the timing cover and clean the whole thing down and do the dye kit. REALLY hoping I don't have to pull the timing/front case etc, as that was just put together by a shop.Definitely how you plan for a new build to go. I've always had really good luck with the UV dye to detect oil leaks. I had something similar that was incredibly difficult to find and it helped identify that a cam seal was leaking which caused drips to come from multiple areas toward the bottom of the engine.
I feel your pain. Perfecting these cars is a roller coaster of progress and setbacks. A good nights sleep, and a little time will help.Well... feeling pretty defeated.
