92AWDHX40
Supporting Member
- 14,520
- 2,746
- May 22, 2007
Kalamazoo,
Michigan
looking to go with 2 - 10s on my setup, gotta order them, and the lines still.
Looks like two -10's and a -12.
It that two -10AN lines feeding the catch can with only one -10AN line exiting? I would think that you'd want at least two lines going to the intake pipe (or one huge one that can outflow the two feed lines).
I am doing two -8AN fittings off the valve cover to the can and a single -8AN line from the can to the intake.I recently placed an order for one of these cansI am doing two -8AN fittings off the valve cover to the can and a single -8AN line from the can to the intake.
Awesome thread guys
Not saying that you did not, but did you check the hood clearance with the 8an fittings screwed to the weld in bung???? I had to cut a section of the brace in the hood so that my 8an's would fit. That is using a 90* NPT weld in, which is shorter than a straight weld in bung and the 90* fitting on top. My total height is 1.2 inches on the front and after 15 or so passes, I can see where it has been hitting the hood. Just checking
For everyone else and the member that contacted me, I am sorry that I have not yet posted the video. I have about 2 hours or so of film covering everything but have yet to find a decent video editing program to condense the film to an appropriate size for viewing. I will post the video once I find a program and compose the video.
Robert
Robert
One thing they mention is that to create a vacuum scenario everything has to be sealed. So what they did is pressure tested the crankcase and fixed what ever leaks show up.
Awesome thread guys
What would you "seal" in a crankcase? If it wasn't sealed everywhere it needs to be, it would be leaking oil.
And pressure testing a crankcase wouldn't be very good for the seals and gaskets.
...and to add to what you ask out crankcase pressure has been tested as high as 5 psi under full boost before.
That is pretty extreme for our engines, but a good example of why you need to run a good PCV system.
http://www.dsmtuners.com/forums/articles-engine-fuel/366890-4g63t-pcv-system.html
Jack was also doing some experimental and out-of-the ordinary things that were causing his excessive pressure.
^Please post a link to those threads if you could, I'm trying to do some research and I couldn't find them on there.
I think i should have asked for an extra 1/8NPT bung on the can so i could put a vacuum/boost gauge on it for some data
Cool deal.
Measuring the pressure inside the can wouldn't tell you much.
Looks like you can use the stock vent location. A 1/8 NPT will thread in there pretty easily; just don't let any metal get into the head. (Run a tap through the VC with it off the car, and use a vacuum to keep metal from getting under the baffles).
Thanks for the update!
There are two M6 x 1.00 bolt holes right there above the battery, they're just a bit offset so one of the M6 x 1.00 bolts is longer and has a spacer on it.gofer, do you have a close up of how you mounted your catch can? I have looked all over my 2g and no way I can mount it as low as you did even with my battery on the subframe. The only place for me to mount it in a similar location are the 2-bolt holes directly above it.
