turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Paul, can't wait to see the results. As for nit-picking the effects, remember that if you can have the hole to be scavenged flush with the inside surface so there's no turbulence and just high speed air causing a low pressure zone over it you will be better off. Lots of drag cars (V8's mainly over the years) have scavenged from the headers but they only run a header, we have back pressure building from the muffler and piping so i don't think that route is as effective for us so we use what we got.. I'm about to tig my new intake pipe up (filter to turbo) and it will have a -8 line tapped from a tube that's flush on the inside, and insce i also have an ECU that will allow me to log a second MAP sensor (and even has it built in) if i get motivated i shall do the same tests as paul just to see how it can vary from ones etup to the next and if my flush surface shows any change in effect over Pauls system where the fitting is physically inside the inlet tube
