Strm Trpr's Eclipse GSX
Mitsubishi Eclipse GSX
|GReddy 18g|GReddy 3" Intake|GReddy Type-RS|ETS Race FMIC w/Ceramic Coated Pipes|Ported 2g Ex Man|LIPP O2 Housing|3" Megan DP|3" High Flow Cat|GReddy Evo Cat-Back|NGK BR7ES|NGKWires|Hallman Pro RX MBC|Seibon Evo Vented Carbon Fiber Hood|Rewired Walbro 255HP|-6AN Braided Hose from Pump---828 Series Fuelab Fuel Filter---Rail---FIC 850's---Aeromotive AFPR---6AN back to Tank|
Mods-Engine
|BSE|
Mods-EMS & Logging
|DSMLink V2.5|ZT-2 Wideband|AEM 3.5 MAP Sensor|Prosport Premium Peak/Hold Water Temp, Oil Pressure, Oil Temp Gauges|
Mods-Drivetrain
|Competition Clutch Stage 4 Sprung 6-Puck Clutch|Competition Clutch Lightweight Chromolly Flywheel|Prothane Motor Mounts|Speed Source Underhood Bushings|Symborski Shifter Base Bushings|
|Work Emotion CR Kai 17x9 +38mm +3mm Hubcentric/Wheelcentric Spacers|255/40 Toyo RA-1's||Tein Flex Coilovers 10kg/6kg|13.3" Wilwood Rotors|6-Piston Wilwood W6A Calipers|Prothane Suspension Bushing Kit|Tanabe Front Lower Tie Bar|RRE Front Lower Tie Bar|Carbing Front Upper Strut Bar|
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
Strm Trpr
More in 2G DSM
Share this Vehicle
