SOADweskey
- 1,224
- 97
- Dec 11, 2006
Jacksonville,
Florida
I didn't want to clutter up 99gst_racer's thread about his really nice setup so i made this one to show another way to increase ventilation size.
Currently I have my system set up to exhaust scavenge in the first bend of my down pipe which is 2.5"( This did not work so it goes back into the intake). I still have not had the opportunity to hook up a second MAP sensor to log the vacuum or pressure in the crank case yet. I'm hoping that will happen in the next week or two after I finish school and get my HX-35 installed.
Here is the start of me laying out what part of the valve cover I wanted to remove.
Here is the section cut out and prepped for welding. I used a Dremel with a cut off wheel to remove the section.
Here are some shots of the aluminum block I made to fit in the vacant section. The only thing not shown in these pictures is that I was able to remove more material from the section of the block that sits inside the valve cover to improve airflow to the vent. I made the decision of how much to remove once I was able to set the block in place in the valve cover and see how much of the block would be inside the cover.
This is a comparison of the new vent sitting next to the stock vent.
Here are some shots of the valve cover finished and the catch can.
The catch can is a Saikou Michi Stage 2 catch can Product Page
