Valve Cover Baffle Project
I noticed by the pictures that a few others have done the same as I did. On the half moon pieces, the two legs are different lengths. One is larger than the other and I noticed this after I had them already welded in. Do they need to all be lined up or does it not matter which way the legs are welded in?
Josh,
It does not matter. They are patterned that way on the OEM unit and the big leg should be on the outside edge on both sides. However, no one has ever had an issue from mixing them up. I should also point out no one can quantify any improvement or change by having them all installed the OEM way either. So your all good.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
