greengoblin
Supporting Vendor
- 1,571
- 398
- Mar 10, 2006
McKinney,
Texas
We had been left with the choice two choice when we want to add fittings or media blast our VC for powder coating.
1. Take the baffles out and leave them out.
2. Leave them in. Cross our fingers and pray nothing became hung up under them and then later dislodged wreaking havoc.
I don't think either of these are good choice so this is what I came up with. I had several very good friends help me with this.I the love the way it turned out. Take a look and see what you think. Nothing super radical just an Aluminum version of the OEM units. The first unit is going to be on Andrew's timeattack eclipse!
Big thanks to Brendon For setting up the drawings for the plasma cutter.
First baffle fully welded together. Now the AN fittings and baffle need to be welded to the VC then on to coating. Thanks to Travis for welding the tabs on the baffles for me!
Andrew's VC for his time attack eclipse.
-10an fitting with custom baffles.
Did it work on the VC I did. Yep.
