Please Support Kiggly Racing
Paul's 1993 GSX - VMC Panda
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
GT30 Variant
Drivetrain
AWD
Build Type
  1. Street
DBB 3076 with FP30 housing, FP exhaust manifold, Tial 44mm MVR, Custom FMIC with 3 inch piping, Fidanza cam gears, AMS VSR intake manifold (modified), RMR throttle body (82.5mm), Jay Racing alt relocation, FIC 2150 injectors, Magnus fuel rail , Sumped OE tank, 2x Bosch 044 fuel pumps, Mishimoto radiator, Jun BL exhaust by Switzer
Mods-Engine
Scat h-beam's, Ross pistons (8.5:1), Arp L19 head studs, Crane 268 cams, 1mm over SS valves, BC springs and retainers, 3g lifters, Felpro head gasket
Mods-EMS & Logging
Link G4+ stand-alone ecu w/ 4 bar map , 4x fail safe stainless sensors, 3 port electronic boost controller, Innovate wideband
Mods-Drivetrain
TRE stage 2 trans, ACT 2600 clutch, ACT flywheel
JIC Magic coilovers, VMC rear upper and lower control arms, VMC active toe eliminator, VMC front crossmember system, urethane rear subframe bushings, tubular mustache bar, MPI steering wheel, Schroth 4-pt harnesses
Dyno HP
433 whp
345 lb/ft
Dyno Type
Mustang Dyno
Dyno Sheet Photo Link
Dyno Shop Name
Force Engineering
Dyno Session Details
92*F ambient temp!! and 60% humidity. E85 fuel.
99gst_racer
More in 1G DSM
Share this Vehicle
