Please Support Kiggly Racing
EagleTSIawd's Talon TSi AWD
Eagle Talon TSi AWD
Front Mount IC,
Synapse BOV re-routed,
3" GM MAF set as blow-through,
ECMLink GM MAF cable,
ID 1000 Injectors,
Aeromotive FPR,
Walbro 255lph Fuel pump,
Evo III Exhaust Manifold,
PT6235R Ball Bearing Turbo,
Evo III O2 housing,
A'PEXi 3" pipe no cat,
X-Force VAREX muffler,
Fluidamper Damper,
Custom Oil Cooler,
Fluidyne Radiator,
FAL Trimline Fan,
Short Shifter,
Saturn Alternator,
Yellow Top Battery,
HID 6000k,
Power Antenna
Mods-Engine
6 bolt,
Balance Shafts Removed,
SCE Titan ICS Head-gasket,
ARP Head Studs
Mods-EMS & Logging
ECMLink V3,
GM 3.3 Bar Sensor,
Boost Gauge,
Hallman PRO Boost Controler,
Wideband/EGT Gauge,
Zetronix WB Sensor,
Zetronix EGT Sensor,
Fuel PSI Gauge
Mods-Drivetrain
Jacks 2.1 Transmission
ACT Xact Flywheel,
Centerforce Dual Friction Clutch,
SS Clutch Line
18" Rims,
Tokico Adjustable Shocks,
Eibach Springs,
Slotted/Drilled Rotors,
SS Brake Lines,
Camber Correction on Rear,
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
EagleTSIawd
More in 2G DSM
Share this Vehicle
