97egl
- 878
- 566
- Feb 6, 2014
Brownsburg,
Indiana
I have a car that I am wanting to fix up for a winter beater. 91 FWD turbo. Its got like 204k miles on it. Compression test 25-50 psi. Head gasket looked brand new but was blown between all cylinders. First thing I checked was the head for warp and its got about .016 warp. I know the service manual says .008 is the limit to machine it and I searched and found guys saying you can go as far as .015 but nobody ever says why that's the limit.
I am not worried about the compression ratio going up. I am not going to be racing it and will barley ever get into any boost maybe a few psi taking off from a stop. I don't care that that cam timing will be slightly off. My only real worry is possible piston to valve clearance issues from milling the head down. I'm guessing I'll have to mill .020 to fix the .016 warp that is has. I know every engine is slightly different and there is not "set" maximum number that you can take off but there has to be an acceptable range. If after .015 the engines may have piston to valve clearance issues I will clay test to verify but I would rather not if the accepted .015 "limit" is for any other reason.
FYI I have already verified the cams spin freely in the journals with the rockers off and I know the head needs to be leak tested but that's just not possible to do with this much warp so I'll have to test it after milling it
