Head clearance service limit question
brynden29
127
May 15, 2002
Round Rock, Texas
Hey guys,
I have searched here and on Talk and cannot find anyone with a similiar issue. I am in the process of rebuilding my engine. The head is done and I am going to get it today. Here is my problem
The stock head size is 5.197 inches. The service limit is 5.185 inches, my head is 5.165 inches after being resurfaced. So it is .02 inches under the service limit. The machine shop guy recommends me using a head saver shim. I am not sure I want to do that.
Here are my questions:
1. Is a head shim a good idea?
2. Can I use my head being that it is .02 under the service limit? Will the valves hit the pistons?
3. Should I get a new head?
I plan on running 18-20 psi on this built motor if that makes a difference. Thanks for the help guys.
I have seen heads that were milled down so far the valves protruded past the surface of the head. Might be a problem if you run cams with more lift than stock though.
Just a little more info, I am running Wiseco 8.3:1 pistons. They do have sizable valve reliefs in them. Thanks again for your help. I do not want to mess up my freshly built motor!
if your so worried run a thicker headgasket to make up the diffrent like a mitsu 4 layer
Get an old headgasket and put some playdough in the valve reliefs in the pistons. Crank it over a few times and take it apart. Measure the thickness of the playdough and that is your clearance.
i work at a machine shop and we've milled heads more then .020" for people before when the limit on the head was around .004" being the limit to how much it can be milled. if anythign check your valve clearance.
Thanks for the replies. I am going to use the "playdoh" method tonight. I have a paper HG that I am not going to use so I am going to put playdoh on my valve reliefs and turn the crank over a few times to check the clearance. I will post the results in case someone else is ever in my same situation and does a search.
By the way the factory manual says .008 is the cut limit. No worries though i have run heads with more cut off with no issues.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
