Bearing clearance hardware question
Craig13
5+ Year Contributor
75
27
Mar 25, 2020
Surprise, Arizona
So this probably seems like a reaaaaallllllyyyyy stupid question but ARP hardware is expensive and I dont wanna F this up. I am getting ready to check my oil clearances for main and rod bearings and I am wondering if I should use the new ARP hardware that will be going in the car when I torque the girdle and rod caps to measure, or should I use the old hardware so the new ones don't get stretched at all before they are installed for final assembly? Thanks for any advice.
Use the new. They don’t stretch from being torqued. They elongate over time from the torque combined with millions of numerous ksi combustion cycles. Also I have personally used bolts then studs just to see the difference and I got swings of up to .0003”.
