2G Main Bearing Clearance (Doubt)
polverari
5+ Year Contributor
100
15
Jan 29, 2018
São Paulo, South America
As I often do in my publications, I apologize first for any language errors.
I did a search here in the forum and didn't find anything that specifically answered my question.
I have found several articles commenting that the original clearance for crankshaft bearings is from 0.008 inches to 0.020 inches.
Using plastigage, I identified that my slack is:
.0010
.0013
.0014
.0010
.0013
According to the manual its fine, but...
I'm making a Stroker (2.3) with plans to reach 470-500 hp (on crank) // 400-450 WHP
I would like to hear from you. If this clearance is ok or if, despite being consistent with the technical manual, is not enough for a project that wants to reach this horsepower.
Thank you.
Agree with bastarddsm, plastiguage is not real accurate but if that's all you have, I'd be really concerned with #1 and #4, I run my 2.3 at .0025" @ a 600Hp level. For what it's worth an old rule of thumb for a modified engine is .001" clearance for every 1" of main diameter, since DSM mains are 2.24" that equates to .0022
I bore gauge ( set with a calibration ring ) the main bores, cap torqued, no bearings, mic the crank ( 4 places per journal ), mic the bearings ( with the correct style mic ), do the math and mix and match the bearings to get as close to the clearance I want ( note: there is very little variation in bearing thickness, maybe ).00001". That said , I always ( just in case I was drinking ) use plastic gauge during final assembly. In my experience plastic gauge is accurate to hundredths (0.00") so if your observations are on the low side of 0.0015" I'd look into undersized 0.001" bearings for #1 & 4. Or if YOU decide to use the In/.001" rule go with all 0.001" undersized. You are shooting for + X2 times stock HP.
Good Luck
Thank you for this information. You said exactly what I was trying to understand: if there was any common sense (or preparation) rule for this question about clearances. Thank you
Good Luck
I think I understand what you mean and I will follow this tip of .0001
I don't know the correct word but.. I will send the crankshaft for polishing to try to get bigger clearances and reach 0.0020''.
Im using ACL bearings 0.001'' (0.025mm)
You cannot polish that much material off a crank and keep it round. If you think of the process,a belt is pressed against a rotating main, it's not backed up and can flap somewhat, it is no where near as accurate as a grinder at a fixed position. If there is somewhere you can get it polished they may have the equipment ( bore gauge, mics ) to accurately measure the slack and once they do you have to find a crank grinder that will adjust each main individually according to those measurements to get the clearance you want.
Solved: I change my 0.025mm ACL bearings for STD bearings with a friend.
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
