jakelandry's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Build Type
  1. Street
FP Race manifold - 62mm bae 7 blade hx40 in .55 bep housing (6an straight from filter housing for feed, ace hardware 3/4 inch drain) - 4inch intake pipe with 9" green filter - Walbro 255hp inline with an A1000 - -8an fuel lines with mr. Gasket fittings - allstar fuel filter - Fic 2150's - Aeromotive afpr and 6an return line - VRSF fmic - true 3" dsm flange O2 housing to 3.5" vibrant resonator side exit exhaust - bj's intake manifold- dumped emusa wastegate - synapse bov - NGK plug wires- br7es - Prothane motor mounts and inserts - 1g tb - Gates racing timing belt - venom cam gears - shaved valve cover with 10an pcv to catch can to intake pipe -
Mods-Engine
jdm 6 bolt swap - ARP headstuds - felpro composite - delta h272's - Self ported head - kiggley beehives - supertech valve seals - Evo 8 lifters -stock valves with a hefty amount of lapping - all stock bottom end less balance shafts
Mods-EMS & Logging
Apexi avcr - Dsmlink v3 full - AEM uego wideband - pro sport oil pressure and boost gauge - ecmlink sd setup
Mods-Drivetrain
qm twin disk on qm flywheel - full ss clutch line
Feal coilovers 11kg/6kg - intrepid rear toe arms - poly bushings everywhere but subframes and rear end - Gram-light 57f 18x8.5 time attack wheels with 235-40 nankang ns2-r's - 3mm spacers up front 10mm rear
Parts Wishlist
Built motor and trans, decent intercooler piping, top mount exhaust manifold, better hx40 exhaust housing
1/8 Mile E/T
7.430
1/8 Mile MPH
99.660
Timeslip Photo Link
Timeslip Details
Fuel Used : E85
Vehicle Weight : stok
Tires : Street Radials
jakelandry
Rating
5.00 star(s) 2 ratings
More in 2G DSM
Share this Vehicle
