Need stock specs for resurfacing 1g head
according to the mitsu factory manual you can remove a combind total of .008 from the head and block.
according to AERA, you can remove .0015 from the head
"new" thickness on the head is 5.200
the head needs to be measured from the CV rail to the HG surface at the 4 corners
if you are thinniner than 4.185 get a thicker head gasket to restore the head thickness back to OE specs.
appox .007 milled closes the combustion chamber by 1cc
