JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
A little comparison for anyone interested in seeing the aero tech of the HTA68 wheel with the compressor cover removed.
The compressor inducer is around 51mm, putting the HTA68 in between the 18G (50.2mm) and the 20G (52.5mm) inducer specs:
The exducer remains the same for all Big 16G thru 20G compressors, 68mm:
From a side-angle comparison to a MHI 20G wheel, you can see that the HTA68 wheel is overall much longer than the standard MHI wheel. The hub area of the HTA68 is also greatly reduced, meaning the HTA68 wheel weighs less and has a much larger surface area to each fin, resulting in greater efficiency:
