skatershawn's Talon N/T (w/turbo)
Ownership Status
Currently Own
Eagle Talon N/T
Turbo Type
20g
Drivetrain
FWD
Build Type
  1. Street
16g/20g hybrid Turbo (20g compressor wheel and housing bolted to 16g hotside (heavely ported) / Kinugawa Wastegate Actuator with 1.5 bar spring /
3in VRS Perfromance Turbo Back w/test pipe (coated and wrapped) /
Upgraded O2 housing w/dump /
Ported 2g Exhaust Manifold /
Gasked Matched/Ported Intake Manifold /
255 Walbro Fuel Pump / FIC 850cc Injectors /
Forge Atmospheric BOV /
Fuel Lab AdjustableFuelPressureRegulator /
SlowboyRacing MBC / 2.5in hard intake pipe (preturbo) / Dejon Tool 2.5in; Upper Intercooler piping w/blow through GM MAF / Custom charge piping with 27x17x2.5" Front Mount Core (no name) /
3in Aluminum Radiator with 12in slim fans and high temp silicon hosing.
Mods-Engine
Pistons bored .020 over w/ Mahle Forged Pistons /
Eagle H Beam Rods / ARP Head Studs
Mods-EMS & Logging
DSM Link V3 Lite / 3in GM MAF / MAF Translator / AEM Wideband o2 sensor / HKS Turbo Timer
Mods-Drivetrain
Exedy Stage 2, Cerametallic, Sprung, 3 Puck Clutch kit
EnergySuspension Prothane Motor Mounts / EnergySuspension Prothane Sway bar and end link bushing kit / Upgraded Cerametallic brake pads on stock DL brake system.
Parts Wishlist
Maybe run E85!! /
Upgrade to V3 Full and run Speed Density /
264/268 Kelford cams, GSC S1 (268/268) cams, or BC Stage 2 (268/272) cams /
Rebuild bottom end as well as new rings.
skatershawn
More in 1G DSM
Share this Vehicle
