AlphaVision's Eclipse GST (AWD swap)
Mitsubishi Eclipse GST
Protane motor mount inserts ::: Cool Car Audio
Mods-Engine
6 bolt long block ::: Manley 8.5:1/H-beams combo ::: Stock intake cam ::: stock N/A 260 degree exhaust cam ::: Kiggly beehives ::: 30 degree valve job ::: Fuelab AFPR@43psi ::: Fidanza adj. cam gears ::: Clevite main/rod bearings ::: ARP head studs & main bolts ::: Cometic MLS ::: Walbro 255HP ::: FIC 1050cc ::: ported FP68HTA turbo ::: FP Race manifold ::: 3" turbo back exhaust ::: Manual Boost Controller ::: 1G BOV /w Dodge mod ::: NGK sparkplug wires ::: NGK BPR-7 ES ::: 1G IM ::: 1G NT TB ::: 29x9x3 FMIC ::: EGR removed ::: AC removed ::: balance shafts removed
Mods-EMS & Logging
1G Socketed EPROM ECU ::: Moates Ostrich 2.0 ::: speed density setup with Jackal/TunerPro RT
Mods-Drivetrain
ACT streetlite flywheel ::: ACT 2600 pressure plate ::: Act street clutch ::: Energy Suspension polyurethane bushings ::: UMS Tuning Rear Diff Bushings ::: B&M Short Shifter ::: Energy suspension sway bar bushings ::: SS Clutch line ::: Slave cylinder extended rod ::: Slave cylinder restrictor removed
17" Gia Cuzzo Reflexx Premium Silver ::: 225x45 ZR17 Yokohama S306 ::: KYB GR-2
Parts Wishlist
Coilovers, HKS 264/272, some nice seats
1/8 Mile E/T
8.043
1/8 Mile MPH
80.000
Timeslip Photo Link
Timeslip Details
Track Name : Kondofrey Drag Challenge 2012
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3450
Tires : Street Radials
Altitude : 1600 ft
Sponsored Car : no
265.3 lb/ft
Dyno Sheet Photo Link
Dyno Shop Name
Heed Auto, Sofia, Bulgaria
Dyno Session Details
Nitrous : No Nitrous
Turbo : FP68HTA
Boost : 21
AlphaVision
More in 2G DSM
Share this Vehicle
